The physical nature of spacetime
In summary, the conversation discusses the concept of spacetime and its relationship with matter and energy. It is described as a mathematical entity, specifically a 4-dimensional semi-Riemannian manifold with a Lorentzian metric, which is curved by matter and energy and influences the movement of matter. The conversation also considers other viewpoints, including the idea that spacetime is not a physical entity but a tool to describe the separations between events. The importance of testing and improving theories through experiments and thought experiments is also emphasized.
  • #36
jimbobjames said:
I was referring to absolute in the sense that the metric and Riemann are geometric objects which are independent of any choice of reference frame.
Of course they are, they are indeed mathematical objects, e.g. abstractions.
General relativity is a relational theory, the manifold has no independent existence, it simply represents the relationships of all space-time events. Or as Rovelli wrote: "We can say that GR is the discovery that there is no spacetime at all".
Note that it is impossible to separate any kind of background on which events happen in general relativity!
With regards to the manifold, see for instance what Rovelli writes in Quantum Gravity:
" In the mathematical formalism of GR we utilize the "spacetime" manifold M, coordinated by x. However, a state of the universe does not correspond to a configuration of fields on M. It corresponds to an equivalence class of field configurations under active diffeomorphisms. An active diffeomorphism changes the localization of the field on M by dragging it around. Therefore localization on M is just gauge: it is physically irrelevant.
In fact, M itself has no physical interpretation, it is just a mathematical device, a gauge artifact. Pre-general-relativistic coordinates xu design points of the physical spacetime manifold "where" things happen...; in GR there is nothing of the sort. M cannot be interpreted as the "set" of physical events, or physical spacetime points "where" the fields take value. It is meaningless to ask whether or not the gravitational field is flat around the point A of M, because there is no physical entity "spacetime point A". Contrary to Newton and Minkowski, there are no spacetime points at all. The Newtonian notions of space and time have disappeared. "
Pretty profound right?
  • #37
@MeJennifer: Thanks a lot for pointing me to these ideas from Rovelli.
From the piece you quoted however, I see no contradiction with what I was saying above.
"localization on M is just gauge: it is physically irrelevant"
and
"M itself has no physical interpretation, it is just a mathematical device"
Above I was coming to the conclusion that the physically significant (ie very real) object was the field (modelled mathematically by the metric and its derivatives) and not necessarily the manifold.
The very real existence of that field could be demonstrated by the instantaneous effect it would have on test particles, which you might introduce into the field, even at large spatial separations from the source of the field.
Were there nothing real (physical) at the location of the experiment - which would otherwise appear to be "empty" space - then there would be no explanation for the relative acceleration of the test particle along a line directly to the centre of mass of the source (and not in any other arbitrary direction).
(I admit that I have only carried out the experiment myself at much shorter distances however :smile:)
