The Physics of Sports Racket Tension
In summary: So there's less of an angle between the racket movement and the ball movement. In summary, the question of whether high or low tension strings on badminton/squash rackets give more power/force does not have a clear answer. Some sources state that lower tension strings create more of a trampoline effect and lead to more power, while others claim that higher tension strings result in greater power. However, the real key to maximizing power and control is finding the optimal string tension for each individual player, which can depend on a variety of factors such as impact speed, location, and angle, as well as the materials and elasticity of the racket. Ultimately, the decision on string tension should be based on personal experience and experimentation rather than
Jimmy87
686
Hi,
I am interested to find out the answer to whether high tension or low tension strings on badminton/squash rackets give more power/force. There are so many conflicting sources on the internet I wanted to see if it can be answered in a concrete way by physics. So, some sources are saying that a lower string tension will create more of a trampoline effect and lead to more power. Some reliable sources such as racket stringing services generally say this. Other sources (including an international badminton coach) say that higher string tension leads to greater power. However, they say that a higher tension does make the sweet spot much smaller so a bad hit on a higher tension racket will have much less power than the same bad hit on a lower tension racket but if both were hit in the sweet spot the higher tension will have much more power.
Is there any modelling of physics that could provide a concrete answer as to which tension would give more power assuming all other variables are held constant such as racket head speed at contact, centre strike etc. Or even just peoples ideas and general thoughts would be great.
Thanks for any insights.
The only source of power/force is your arm, not the strings. That doesn't mean rackets don't differ, but it does mean you need a different language to discuss the differences.
Are you asking how to maximize the elasticity of the collision (minimize dissipated energy)?
Yeh I think so. I am basically asking that if you had two rackets which made contact with the ball/shuttle with the same racket head speed but one racket had strings with a higher tension than the other which racket would cause the ball/shuttle to leave the racket head with a higher velocity. There is so much inconsistency with sources - some saying higher tension strings gives more power, some saying looser strings. From my own experience of playing badminton I definitely have experienced more power (faster shuttle speed) with higher tension rackets but the sweet spot definitely gets smaller so any off center hits either break the strings or have much less power/shuttle speed. I just wanted some physics to be applied to this to confirm whether higher or lower string tension gives a higher shuttle speed.
Jimmy87 said:
For example, this forum on the subject produces about a 50/50 split in terms of who thinks tighter strings produce more power.
http://www.badmintoncentral.com/for...-smash-from-tighter-or-looser-strings.108492/
Most of the analysis on that forum is muddled, to say the least. First, the underlying physics is clear: all the energy comes from the initial energy of the shuttle and the player. Nothing else in the system can actually generate energy. So, it's really a more complex question of how the equipment can a) maximise energy transfer from the player's muscles and b) minimise energy lost during the collision.
Now, consider the following:
You have a cricket bat, a tennis racket and a badminton racket. And, you have a cricket ball, a tennis ball and a shuttle. That gives you nine combinations of racket and object to be hit.
In each case, the solution goes beyond the basic physics, and illustrates that, unfortunately, you can't just do some energy-momentum equations and get the answer.
The simple fact is that you need a more specific and experimentally-based analysis of the effect of tighter strings: it may critically depend on the mass of the shuttle, for example. It may also depend on the player and the way they swing the racket: someone with perfect technique may find, say, tighter strings better; whereas, someone with less snap in their wrist may benefit from looser strings. In other words, racket-head speed could be another major factor.
Likes Jimmy87
I would rather look for experimental results done by some racket company. This is not easy to compute.
This makes sense to me intuitively. There should be an optimal string tension for any combination of:
- impact speed
- impact location
- impact angle
- shuttle mass
- material properties of the strings
- material properties of the head
- elasticity of the racket frame
So there is no general rule saying that more tension is better or worse.
Likes Jimmy87
Jimmy87 said:
Hi,
As pointed out, there's not really a clear answer to this question. However, there is a clear answer to a related question, which is that lower tension strings increase the amount of time the ball is in contact with the racquet, which provides the player an increased sense of control:
http://www.tennisindustrymag.com/articles/2005/01/does_higher_string_tension_giv.html
Likes Jimmy87
I can imagine that for non-perpendicular impacts, less tension makes final ball/shuttlecock movement direction closer the to the racket movement direction.
Related to The Physics of Sports Racket Tension
1. What is racket tension and why is it important in sports?
Racket tension refers to the amount of force that is applied to the strings of a sports racket. It is important because it affects the way the racket interacts with the ball, ultimately impacting the power, control, and spin of each shot.
2. How does racket tension affect the performance of a racket?
Racket tension directly affects the stiffness of the strings, which in turn affects the amount of energy transferred to the ball upon impact. A higher tension results in a stiffer string bed, which can provide more control and accuracy, while a lower tension creates a more elastic string bed, offering more power and spin potential.
3. What is the ideal tension for different types of sports and players?
The ideal tension for a racket depends on the type of sport, the player's style of play, and personal preference. Generally, a higher tension is recommended for sports that require precision and control, such as tennis, while a lower tension may be preferred for sports that require power and spin, such as badminton.
4. How often should a racket's tension be adjusted?
The tension of a racket can change over time due to factors such as temperature, humidity, and usage. It is recommended to have the tension checked and adjusted every few months for frequent players, and before important competitions or matches.
5. Are there any risks or drawbacks to changing the tension of a racket?
Changing the tension of a racket can affect its performance and may take some time for the player to adjust to the new feel. Additionally, frequent tension adjustments can cause wear and tear on the racket's strings, leading to a shorter lifespan of the racket.
  • Mechanics
25K
  • Other Physics Topics
