The polynomial is irreducible iff the condition is satisfied
In summary, we need to show that the polynomial $f(x)=x^n+1$ is irreducible if and only if $n=2^k$ for some integer $k \geq 0$. We can do this by noting that $n$ must be of the form $2^k\ell$, where $\ell$ is an odd integer. This means that $x^{2^k\ell}+1$ can be factored as $(x^{2^k})^\ell+1$, which implies that if $\ell>1$, then $x^{2^k}+1$ is a proper factor of $x^n+1$. If $\ell=1$, we can show that $(
mathmari
MHB
5,049
Hey! :eek:
I need some help at the following exercise:
Show that the polynomial $f(x)=x^n+1 \in \mathbb{Q}[x]$ is irreducible if and only if $n=2^k$ for some integer $k \geq 0$.
Could you give me some hints what I could do?? (Wondering)
This is a fairly straightforward algebra exercise. Hint : show that
$$x^{2n+1} + 1 = (x + 1)\left ( x^{2n} - x^{2n-1} + \cdots - x + 1 \right)$$
mathmari said:
Hey! :eek:
Hi mathmari,
Note that $n$ is of the form $2^k \ell$, where $k \ge 0$ and $\ell$ is odd. Thus $x^n + 1 = x^{2^k \ell} + 1 = (x^{2^k})^{\ell} + 1$. Hence, if $\ell > 1$, $x^{2^k} + 1$ is a proper factor of $x^n + 1$. In case $\ell = 1$, show that $(x + 1)^n + 1$ is irreducible by application of Eisenstein's criterion with $p = 2$. Show that this implies $x^n + 1$ is irreducible.
Eh, Eisenstein's criterion is a bit too much. Some easy polynomial factorizations, Gauss lemma and a pack of popcorns does the trick.
Sure! To prove this statement, we can use the fact that a polynomial $f(x) \in \mathbb{Q}[x]$ is irreducible if and only if it does not have any roots in $\mathbb{Q}$.
Hint 1: Consider the roots of $f(x)$ in an extension field of $\mathbb{Q}$.
Hint 2: Recall that $x^n+1$ can be factored as $(x+1)(x^{n-1}-x^{n-2}+...+x^2-x+1)$.
Hint 3: Use induction on $n$ to show that if $n=2^k$, then $f(x)$ does not have any roots in $\mathbb{Q}$.
Hint 4: For the converse, use the fact that if $f(x)$ is irreducible, then any factor of $f(x)$ must have degree $n$ or $0$.
Hope this helps!
FAQ: The polynomial is irreducible iff the condition is satisfied
1. What does it mean for a polynomial to be irreducible?
An irreducible polynomial is one that cannot be factored into lower degree polynomials with coefficients in the same field.
2. How can I tell if a polynomial is irreducible?
One way to determine if a polynomial is irreducible is to check if it has any rational roots. If it does not have any rational roots, it may be irreducible. However, this is not a foolproof method and other techniques may be necessary.
3. What is the condition that must be satisfied for a polynomial to be irreducible?
The condition for a polynomial to be irreducible is that it cannot be factored into lower degree polynomials with coefficients in the same field.
4. Can a polynomial be both reducible and irreducible?
No, a polynomial cannot be both reducible and irreducible. It must fall into one category or the other.
5. Why is it important to determine if a polynomial is irreducible?
Determining if a polynomial is irreducible can help in various mathematical and scientific applications, such as solving equations, finding roots, and understanding the properties of the polynomial. It can also provide insights into the structure and behavior of the polynomial.
