The possible lightest material
  • Thread starter Eagle9
  • Tags
    Material
In summary, the possible lightest material is a highly sought after material for various industries, including aerospace and automotive. The current contenders for this title include graphene aerogel, silica aerogel, and metallic microlattice. These materials are extremely lightweight and possess impressive strength and durability. While each material has its own unique properties, they all have the potential to revolutionize the way we design and create structures. Continued research and development in this area may lead to even lighter and stronger materials in the future.
Eagle9
238
I wonder to know where the lower limit for solid substances’ density is. We know that some solid materials are lighter than liquids (ice, wax and etc), but can the solid material in principle be lighter than air? For example the density for Carbon nanotube is at least ten times less than water’s one (data taken from here: http://en.wikipedia.org/wiki/Specific_strength ). What Physic’s laws say about this? Is substance’s lower boundary for density somehow restricted? :smile:
The point about a gas (say, air) is that a given amount of gas molecules will take up any volume you offer it. That means that there is no lower limit to the density of a gas. This cannot be beaten by any solid.
Or are you wondering whether any solid could in principle have a density of less than about 1.2 kg/m^3? (air density under standard circumstances is somewhere in that region). In that case the answer is "in principle most likely yes" (think of a hard foam filled with helium).
cgk
Yes :smile:
Borek
Great! Almost as dense as air! Perhaps very soon the scientist will invent even lighter material that will enable us to make some armor that we will wear and fly in air :smile:
Quite the opposite - air is almost as dense as the lightest aerogel made up to now.
Hrmm. If only it could work like this... =)
Could you please tell me where is it possible to find information about Aerogel’s other properties? I need to know the value of tensile strength for this material but these web-sites:
http://en.wikipedia.org/wiki/Aerogel#Silica
http://en.wikipedia.org/wiki/Tensile_strength
Do not provide such information :smile:
At this site:
http://eetd.lbl.gov/ecs/aerogels/sa-physical.html
It is written that tensile strength for Silica Aerogels is 16 kPa for the density of 0.1 g/cm^3, but what about the Aerogels with the lowest density- 1.9 mg/cm^3?
FAQ: The possible lightest material
1. What is the possible lightest material?
The possible lightest material is a material that has a very low density, making it extremely lightweight.
2. How is the possible lightest material made?
The possible lightest material is typically made through a process called aerogel synthesis, which involves creating a gel and then removing the liquid component through a process called supercritical drying.
3. What are the potential applications of the possible lightest material?
The possible lightest material has a wide range of potential applications, including in aerospace technology, insulation, and as a lightweight structural material.
4. Is the possible lightest material strong?
While the possible lightest material is very lightweight, it may not necessarily be strong. Its strength depends on the specific material and its structure, but it is generally not as strong as other materials such as metals.
5. How does the possible lightest material compare to other lightweight materials?
The possible lightest material is often considered to be the lightest solid material, but there are other materials such as graphene aerogel that are even lighter. However, the possible lightest material is still a highly impressive and useful material.
