The Potential of Back-to-Back Photons: an Experiment
In summary, the experiment produces a ring of photons on the left side corresponding to photons that got diffracted to the bright spot on the right.
Grelbr42
68
125
TL;DR Summary
Back to back photons in coincidence detector
In some cases, photons can be produced in "back to back" (BTB) conditions. For example, electron-positron annihilation produces two photons, each at 0.511 MeV, with equal and opposite momentum. Or pretty close, up to the original velocities of the electron and positron.
Start with a source of such BTB photons. Put it at the middle of a sphere of detectors. It should produce a uniform probability of photons anywhere in that sphere. Now put some diffraction barriers on one side. For example, if you put in a ring you should be able to produce a situation where the signal is higher through the center of the ring. It should be brighter at the center than without the ring.
So, crank down the intensity until you can discern which photons belong together. When a photon is detected at some location, the paired photon should be detected at the same time.
Now save only photon pairs such that one photon arrives at the "bright spot" at the right, and the other arrives anywhere.
Brace yourself for my poor artistic style. It should look something like so.
So there should be a spot on the left side corresponding to photons that "went straight through" the diffraction barrier. But there should also be a ring of photons on the left side corresponding to photons that got diffracted to the bright spot on the right.
So, without the diffraction barrier, the paired photons should be completely back-to-back. But with it, and saving only those such that one arrives at the bright spot at the right, then on the left there should be a dot and a ring.
Has such an experiment ever been done? And is my estimation of what would be the result correct?
What you describe is PET imaging. However, at 511 keV the wavelength is substantially smaller than a single atom. So diffraction is essentially nonexistent.
Likes hutchphd, berkeman, Grelbr42 and 2 others
Thank you Dale! I learned something today.
Indeed, reading the Wikipedia article tells me a lot of cool info.
https://en.wikipedia.org/wiki/Positron_emission_tomography
The patient takes a dose of a substance that emits positrons. These then migrate through the body. The scanner then detects paired photons. The path of the paired photons gives a line on which the positron was emitted. And the difference in arrival time between the two ends gives the position along that line. Thus a 3-D image is possible.
By selecting source isotopes of different chemical elements, it is possible to tailor source molecules that will tend to migrate to the portion of the body of interest. The result is that tissue can be imaged with lower overall dose and higher resolution.
In addition to imaging, it is possible to trace the process of various chemicals through the tissue. One application is that the efficiency of drugs getting to where they are needed can be measured. It lets drugs be modified so they go more where they are needed and less where they are not needed.
Very cool!
Likes Dale, PeroK and berkeman
So, follow-on question. Is there a convenient source of paired photons at lower energy? Say somewhere from visible light to microwaves? Lower energy photons means no dose and possibly some diffraction.
Not that I know of, but my expertise is in medical imaging. There may be some quantum mechanical sources that I don’t know about
FAQ: The Potential of Back-to-Back Photons: an Experiment
What is the primary objective of the "The Potential of Back-to-Back Photons" experiment?
The primary objective of the experiment is to investigate the quantum mechanical properties and potential applications of back-to-back photon pairs, which are photons emitted in opposite directions with correlated properties. This research aims to explore their use in quantum communication, quantum computing, and fundamental tests of quantum mechanics.
How are back-to-back photons generated in the experiment?
Back-to-back photons are typically generated using a process called spontaneous parametric down-conversion (SPDC). In this process, a nonlinear crystal is illuminated by a laser beam, resulting in the emission of photon pairs that travel in opposite directions while conserving energy and momentum.
What are the potential applications of back-to-back photons?
Potential applications of back-to-back photons include quantum communication (such as quantum key distribution), quantum computing (for entanglement-based protocols), and fundamental tests of quantum mechanics (like Bell's inequality tests). These photons can also be used in precision measurements and quantum imaging.
What challenges are associated with the detection and measurement of back-to-back photons?
Challenges associated with the detection and measurement of back-to-back photons include the need for highly efficient and low-noise photon detectors, precise alignment of optical components, and maintaining the coherence and entanglement of the photon pairs over long distances. Additionally, environmental factors such as temperature fluctuations and vibrations can affect the experimental setup.
What are the expected outcomes or implications of this experiment for the field of quantum mechanics?
The expected outcomes of this experiment include a better understanding of the entanglement properties of back-to-back photons and their potential to improve quantum communication and computation technologies. The results could also provide insights into the fundamental nature of quantum mechanics and help refine theoretical models. Successful demonstration of these concepts may lead to advancements in secure communication and information processing technologies.
