The power rule and the chains rule
In summary, the power rule is a mathematical principle that allows us to find the derivative of a function raised to a power. To apply it, we bring the exponent down in front of the function and subtract 1 from the original exponent. The chains rule is another mathematical principle that helps us find the derivative of a composite function. To apply it, we identify the inner and outer functions and multiply the derivative of the outer function by the derivative of the inner function. These two rules can be used together to find the derivative of a function with both powers and composite functions.
Cacophony
41
How do I know for sure when to use the power rule instead of the chain rule and vice versa?
power rule is used when there are no variables in the raised part (ie. x^2 or 3x^6) but chain rule is used if there are variables in the raised part (ie. d/dx (e^(2x))=e^(2x) * d/dx (2x) = 2e^(2x) Chain rule is used in other situations but this is basically the situation where you would have to decide between chain and power rule as you are asking.
FAQ: The power rule and the chains rule
What is the power rule?
The power rule, also known as the exponent rule, is a mathematical principle that allows us to find the derivative of a function raised to a power. It states that if a function f(x) is raised to a constant power n, then its derivative is n times f(x) to the power of n-1.
How do you apply the power rule?
To apply the power rule, we simply need to bring the exponent down in front of the function and subtract 1 from the original exponent. For example, if we have the function f(x) = x^3, its derivative would be f'(x) = 3x^(3-1) = 3x^2.
What is the chains rule?
The chains rule, also known as the chain rule, is a mathematical principle that allows us to find the derivative of a composite function. It states that if a function is composed of two or more functions, then its derivative is equal to the derivative of the outer function multiplied by the derivative of the inner function.
How do you apply the chains rule?
To apply the chains rule, we first identify the inner function and the outer function. Then, we take the derivative of the outer function, leaving the inner function untouched, and multiply it by the derivative of the inner function. For example, if we have the function f(x) = (3x^2+1)^5, its derivative would be f'(x) = 5(3x^2+1)^4 * 6x = 30x(3x^2+1)^4.
Can you use the power rule and chains rule together?
Yes, the power rule and chains rule can be used together to find the derivative of a function that involves both powers and composite functions. We first apply the chains rule to find the derivative of the composite function, and then apply the power rule to find the derivative of the resulting function raised to a power.
