The pressure term in Bernoulli's equation
In summary, the Bernoulli equation describes the relationship between pressure, velocity, and cross-sectional area in a fluid flowing through a constriction. The pressure decrease is due to the increase in velocity, which is caused by the decrease in cross-sectional area. The force exerted by the fluid is also affected by the converging walls, which push back on the flow. The Bernoulli equation takes all of these factors into account to show how the pressure term changes as the velocity and cross-sectional area change.
Since1333
Seeing as P(F/A) + KE + PE = Constant, if the fluid's flowing through a constriction (So the area's decreasing(Which would net an overall larger pressure)), How does the pressure term decrease? Does the Force decrease even more greatly than the Area, to net an overall lower pressure?
Assuming we're going from a larger area, through a constriction, into a smaller area.
Just to note: I know it's decreasing because either the KE or PE are increasing, i understand that. I'm just confused as to if it's actually the Force(P=F/A) increasing/decreasing significantly to make up for the Area increase/decrease at points.
Remember that the pressure decrease is where the velocity has already increased after the area decrease has already happened. So the pressure there is lower than the pressure that was pushing it into the constriction. The trade-off between average molecular velocity in the direction of flow and the average random molecular velocity that causes non-directional pressure can be imagined as a simple application of the Pythagorean Theorem.
Likes Since1333
Say we want to represent Pressure as Force/Area though, and the cross-sectional area of a (horizontal) pipe decreases(in this hypothetical situation), we will have a decrease in pressure (F/A in this situation), and an increase in velocity. So is force decreasing by a larger amount, to make up for the area that is also decreasing? (Otherwise, a smaller area would just net an even larger pressure(F/A))
Also thank you for your reply, i really appreciate the help
The converging walls are also exerting a force on the fluid in the direction opposite to its direction of flow. So the upstream pressure has to overcome this too.
Likes FactChecker
You should be careful about your terminology. The term "pressure" is used in different ways. There is dynamic pressure, d, and static pressure, s, which correspond to the kinetic and potential energy, respectively. They total to the total pressure, p = d + s. The connection between dynamic pressure, d, and velocity, v, is d = ½ρv2. In a steady-state condition, p is constant and the rate of material flowing through the tube at every point is equal. So the product of the area, A, and v is constant. You should be able to piece those facts together to get your equation.
So the P term in bernoulli's equation P+½ρv^2+ρgh=constant isn't the same type of pressure usually represented as P=F/A?
Actually, that is exactly what it is.
So when the pressure term increases/decreases from a change in velocity, the force(in the term P=F/A) would be considered to increase/decrease to overcome the new smaller/larger area, right?
My example thought is below:
If we were going from an area of low velocity, to high velocity, the pipe's cross-sectional area would be smaller, so for pressure to decrease the force term would have to decrease to overcome the new, smaller area. Otherwise the force over the new, smaller area, would just cause pressure to increase.
I'm just confused as to how the P term physically looks as it changes, as it's represented as F/A, if it's as simple as Force overcoming the change in area, or if I'm missing something
No. This is not the whole story. The fluid is accelerating as it flows from the larger cross section region to the lower cross section region. In order of this to happen, the upstream force must be higher than the downstream force. You know, Fnet = ma, right? But, the converging wall is pushing back on the fluid. This is part of the force balance too. However, the net effect is still that the upstream pressure must be higher than the downstream pressure. The combination of these factors is captured by the Bernoulli equation.
Likes Since1333
This is exactly what i was looking for, thank you.
In case you're wondering about the effect of the converging wall pushing back on the flow, it's taken care of in the frame invariant version of Bernoulli's equation for constricted flow:
## p1 - p2 = \frac{\rho}{2} \ (v2 - v1)^2 \ ( \frac{a1 + a2}{a1 - a2} )##
http://www.loreto.unican.es/Carpeta2012/EJP%28Mungan%29Bernoulli%282011%29.pdf
Likes Since1333
Actually, one more question. If we mathematically represent the P=(F/A) term as P=Mass*Acceleration/Area, what exactly would be increasing/decreasing? Does Mass increase/decrease at all? Or is it only acceleration increasing/decreasing?
You can't represent P = F/A = ma/A because F is not equal to ma. Fnet = ma, where Fnet is the NET force acting on a body. F = ma does not apply to each and every individual force acting on a body. How could a set of different forces all give the same acceleration?
Related to The pressure term in Bernoulli's equation
What is Bernoulli's equation?
Bernoulli's equation is a fundamental equation in fluid dynamics, named after Swiss mathematician Daniel Bernoulli. It relates the pressure, velocity, and elevation of a fluid at any point in a streamline.
What is the pressure term in Bernoulli's equation?
The pressure term in Bernoulli's equation refers to the pressure of a fluid at a specific point in a streamline. It is one of the three main variables in the equation and represents the force per unit area exerted by the fluid on its surroundings.
Why is the pressure term important in Bernoulli's equation?
The pressure term is important in Bernoulli's equation because it helps calculate the energy of a fluid at a given point in a streamline. By understanding the pressure at various points, we can determine the behavior of fluids in different scenarios, such as in pipes or around objects.
How is the pressure term related to the other variables in Bernoulli's equation?
The pressure term is inversely related to the velocity term and directly related to the elevation term in Bernoulli's equation. This means that as the velocity of a fluid increases, the pressure decreases, and as the elevation increases, the pressure also increases. This relationship helps explain why airplanes can fly and how water can flow uphill in some situations.
What are some real-life applications of Bernoulli's equation and the pressure term?
Bernoulli's equation and the pressure term have many real-life applications in fields such as aviation, hydraulics, and meteorology. For example, they are used to design airplane wings, calculate water flow in pipes, and predict weather patterns. They are also essential in understanding the behavior of fluids in medical procedures, such as blood flow in the body.
  • Mechanics
  • Mechanics
