- #36
- 23,591
- 5,833
Toolbox13 said:Hi
On what you term the first question, you are correct but it is generally not necessary to delve into the tensors of Reynolds and normal stresses when control volumes are considered. I am quite familiar with the dissipation term in the differential energy equation, actually spent quite a while working with it. The above result that propose from the textbook I expect is easily found from the first law Q-W=d(H)+d(KE)+d(PE). For throttle everything except d(H) is assumed to go to zero. You may then expand out d(H) and show that viscous dissipation results in a temperature change but then this would contradict the constant h across the throttle assumption (which must be true since it is simply energy conservation afterall). So I think one can view it from two perspectives,
Allow the frictional work to show up in the energy equation giving W(viscous) = d(H) but this implies the the control volume must be drawn within the throttle rather than around it.
Or allow h to be constant when control volume is drawn around the throttle and then split the enthalphy into two terms, u+PV, the u term can then be assigned to equal the viscous dissipation (Cv(dT)) and hence giving a temperature rise. This initially seems in conflict with the constant enthalpy requirement as it indicates a temperature rise but this temperature rise is compensation for by the (V−T∂V∂T)dP using your equation above. This way the enthalpy can remain constant even though there is a pressure rise.
Both ways to think about it are probably reasonable and I think correct.
I looked over Chapter 11 in Bird, Stewart, and Lightfoot last night, and I'm very confident you are going to find the answers to all your questions in that chapter. Unfortunately, I have not been able to articulate the essence of that development in a way that satisfies your doubts.
I also am sending you a private message in which I am proposing that we work together to apply the equations in BSL to solve a specific problem, in order to develop a practical understanding of exactly what is going on. I hope you are interested in participating.
Chet
