I The probability density of a wave function due to length contraction
Wo Wala Moiz
Will the probability density of a wave function be affected by length contraction due to special relativity?
Please post the valid references that you have been reading about this question. Thanks.
The interpretation of the wave function as a probability density in position space comes from non-relativistic quantum mechanics so doesn’t apply when relativistic effects like length contraction are significant. For that you will need the methods of quantum field theory.
Likes Demystifier and PeterDonis
Is it necessary? This question relies on two physics basics- that particles have a wave function whereupon they have a range of probability of positions and momentum over a set volume, and that in high accelerations/velocities, length contraction takes place.
So how does the interpretation differ in QFT?
Note that QM is based on the Schrodinger equation, which is manifestly non-relativistic. The equation has a first order time derivative and second order spatial derivatives. That rules out compatibility with relativity.
By contrast, the Dirac equation is the upgraded relativitistic equation for the electron.
Full-blown QFT is a different approach altogether. With quantum fields replacing single particle wave functions.
So do the quantum fields experience length contraction?
Try to look it up, PF encourages users to look for themselves and show some intent to answer their question by themselves. Try something some search prompt like "Lorentz transformation for quantum fields" for example. That's what is asked when we ask for valid references. It also avoids multiplying the effort.
Well, there’s no wave function to interpret. As @PeroK says, it’s a completely different approach.
As for what there is…. That’s at least an entire semester question. Lancaster and Blundell’s “Quantum field theory for the gifted amateur” is the most approachable treatment that I’ve seen, but you have to buy it.
The question makes no sense. A field isn’t a thing that can contract.
Nothing experiences length contraction. It's a coordinate effect. Like experiencing being looked at from a different angle.
Likes weirdoguy, phinds and pines-demon
Why not?
If we were to visualise the gravitational "force" as being made of field lines, the length contraction caused from the perspective of a moving observer would (intuitively, and of course I could be wrong) cause the field lines along the direction of travel to move closer together.
Wo Wala Moiz said:
Why not?
The fields of quantum field theory are not the classical field lines that you're thinking about here.
Likes Wo Wala Moiz
Wo Wala Moiz said:
Why not?
Newton's law of gravity is not compatible with relativity. Again the statement of the law is manifestly non-relativistic. That's why Einstein developed the general theory of relativity. In that theory, the laws of physics are coordinate independent. The basic concepts of time dilation and length contraction are subsumed into coordinate independent laws, which do not depend on a particular class of reference frame.
Likes PeterDonis and Nugatory
Then we are not doing relativity, because in relativity, gravity is not a force, and there is no such thing as "field lines" for gravity.
Wo Wala Moiz said:
Why not?
No, it would make them APPEAR to move closer together. You seem to still feel that things "experience" length contraction, whereas in reality this is purely an observational artifact. It is, as @PeroK said, like looking at something from a different angle. The thing itself doesn't change, just your observation of it does.
I put quotation marks around "force" for a reason. It is a pseudoforce like centrifugal force.
No, it is not a "pseudoforce" in GR, it is no kind of force at all and pretending otherwise isn't going to get you anywhere. Gravity in GR is space-time curvature. Period.
Is centrifugal force a real force?
Not in GR it isn't.
In GR, there is no such thing as "centrifugal force". You need to stop using concepts from Newtonian gravity.
@Wo Wala Moiz you clearly are just either not paying attention to what you are being told or you don't believe what you are being told. You would be better off, and learn more, if you would drop whichever of those it is. Getting straight between what's Newtonian and what's GR can, I guess, be confusing, but you would do well to get solid on the two since you keep mixing them up.
Guys I think you are too harsh on Wo. It makes perfect sense to study Lorentz contraction of a relativistic quantum field, in the same sense it makes sense to study Lorentz contraction of a relativistic classical field. Furthermore, by the principle of equivalence, gravity in GR is locally very much analogous to inertial pseudo-forces of Newtonian mechanics.
Likes Albertus Magnus, Wo Wala Moiz, AlexB23 and 1 other person
