MHB The Probability of a Biased Coin: n Flips, m Heads
  • Thread starter Thread starter markosheehan
    Probability
The discussion centers on calculating the probability of obtaining a specific sequence of heads and tails when flipping a biased coin. The probability of getting heads is denoted as p, while tails is 1-p. The probability of observing m heads in n flips is derived using the binomial probability formula: P(X) = {n choose m} * p^m * (1-p)^(n-m). There is clarification on whether the problem specifically asks for a sequence of m heads followed by n-m tails, which is not the case, as the formula accounts for any arrangement of heads and tails. Ultimately, the correct interpretation aligns with the binomial distribution, confirming the probability calculation.
markosheehan
the probability of getting a head on flipping a biased coin is p. the coin is flipped n times producing a sequence containing m heads and (n-m) tails what is the probability of obtaining this sequence from n flips.
i can't understand the wording
Mathematics news on Phys.org
I've moved this thread since our advanced forum is for calculus based stats.
A few things we need to observe:
The probability of getting heads is:
$$P(H)=p$$
Now, we know that it is certain that we will either get heads or tails, so we may state:
$$P(H)+P(T)=1\implies P(T)=1-P(H)=1-p$$
So, the probability of getting $m$ heads is:
$$P\left(H_m\right)=p^m$$
And the probability of getting $n-m$ tails is:
$$P\left(T_{n-m}\right)=(1-p)^{n-m}$$
Next we need to look at the number $N$ of ways to choose $m$ from $n$:
$$N={n \choose m}$$
Can you put all this together to find the requested probability?
when i put this all together i get (n ncr m)*p*(1-p)^n-m however at the back of the book it says the answer is p^m(1-p)^n-m
What I get is:
$$P(X)={n \choose m}p^m(1-p)^{n-m}$$
And this agrees with the binomial probability formula. :D
This is the probability of getting any sequence with $m$ heads, for any particular such sequence, then it would be:
$$P(X)=p^m(1-p)^{n-m}$$
Was it possible that the problem asked for the probability of m heads in a row followed by n-m tails in a row? As MarkFl said, that probability if for any particular such sequence- "m heads in a row followed by n- m tails in a row" or "n- m tails in a row followed by m heads in a row" or "A head, then a tail, then a head, followed by m- 2 heads in a row, followed by n- m- 1 tails in a row", etc.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
