The problem described with image in topic
In summary, the formula for calculating the X and Y velocities of a body with a force F in the direction B(β) is X velocity = cos(α-β)*F and Y velocity = sin(α-β)*F, where α is the angle of the object. However, if α=0 and β=-90, both velocities cannot be equal to 0 and the force would only be applied in the Y direction. This may be a limitation in the application of right-angle trig in this scenario.
kustrle
[PLAIN]http://img842.imageshack.us/img842/336/angleqj.png
Lets say that the body has force F in the direction B(β).
What is the formula that would let me calculate X velocity and Y velocity of the body?
The formula should include all three factors, A(α), B(β), and F (force of the body)
I've encountered this problem while developing computer game. Thanks for help!
~Kustrle
Create a right triangle with F as the hypotenuse and one side being the X Velocity and the other side being the Y velocity. Then if you know the angle of the object, you can use right-angle trig to figure out the other sides.
Sorry about the error in posting, accidentally pressed 'post quick reply' instead of 'go advanced.'
I can only include 1 angle (α) and force in right triangle (other angle will always be 90-α).
You only need one angle and one side.
For the angle I take γ=α-β
From that I get that X velocity = cosγ*F and Y velocity = sinγ*F
Now let's say that α=0 and β=-90. It's obvious that both X and Y velocities are equal to 0. But from the equations above I get that X velocity = 0 while Y velocity = F which is wrong.
No they wouldn't both be zero. If F is only in one direction, one vector will have all of the force and the other will have none.
Yes all the force would be in Y direction, but it just couldn't be applied so Y velocity would still be 0.
I don't understand what's wrong, if you just use right angle trig I know it will work out, it's basic vectors.
FAQ: The problem described with image in topic
What is the problem described in the image?
The image describes a large amount of plastic waste floating in the ocean, also known as the "Great Pacific Garbage Patch".
How did this problem occur?
The problem occurred due to the improper disposal of plastic waste by humans. This waste ends up in the ocean through littering, improper waste management, and ocean dumping.
What are the effects of this problem?
The plastic waste in the ocean has numerous negative effects on marine life, such as entanglement and ingestion. It also harms the ocean ecosystem, disrupts food chains, and can impact human health through the consumption of contaminated seafood.
What is being done to address this problem?
Efforts to address this problem include clean-up initiatives, waste reduction and recycling programs, and policies to reduce plastic use. Scientists are also researching ways to remove plastic waste from the ocean and prevent it from entering in the first place.
What can I do to help with this problem?
Individuals can help by reducing their use of single-use plastics, properly disposing of waste, participating in beach clean-ups, and supporting policies and initiatives that aim to reduce plastic pollution in the ocean.
