MHB The product γ is a rotation or a translation
mathmari
MHB
Hey! :giggle:
For $p\in \mathbb{R}^2$ let $\delta_{p,\alpha}=\tau_p\circ \delta_{\alpha}\circ\tau_p^{-1}$.
Let $p,q\in\mathbb{R}^2$ and $\alpha,\beta\in \mathbb{R}$.
(a) Show that $\gamma=\delta_{p,\alpha}\circ\delta_{q,\beta}$ is a rotation of a translation (or both). Give the center of the rotation or the translation vector of $\gamma$ in respect to $p,q,\alpha, \beta$.
(b) Show analytically that the product $\gamma$ of two line reflections is a rotation or a translation. Give the geometric interpretation of the rotation angle/translation vector of $\beta$.
For (a) I have done the following :
\begin{align*}\left(\delta_{p,\alpha}\circ\delta_{q,\beta}\right )(x)&=\left (\tau_p\circ \delta_{\alpha}\circ\tau_p^{-1}\circ\tau_q\circ \delta_{\beta}\circ\tau_q^{-1}\right )(x)\\& =\tau_p\left ( \delta_{\alpha}\left (\tau_p^{-1}\left (\tau_q\left (\delta_{\beta}\left (\tau_q^{-1}(x)\right )\right )\right )\right)\right )\\ & =\tau_p\left ( \delta_{\alpha}\left (\tau_p^{-1}\left (\tau_q\left (\delta_{\beta}\left (x-q\right )\right )\right )\right)\right ) \\ & =\tau_p\left ( \delta_{\alpha}\left (\tau_p^{-1}\left (\tau_q\left (d_{\beta}\left (x-q\right )\right )\right )\right)\right )\\ & =\tau_p\left ( \delta_{\alpha}\left (\tau_p^{-1}\left (d_{\beta}\left (x-q\right )+q\right )\right)\right )\\ & =\tau_p\left ( \delta_{\alpha}\left (d_{\beta}\left (x-q\right )+q-p\right)\right )\\ & =\tau_p\left ( d_{\alpha}\left (d_{\beta}\left (x-q\right )+q-p\right)\right )\\ & = d_{\alpha}\left (d_{\beta}\left (x-q\right )+q-p\right)+p\\ & = d_{\alpha}d_{\beta}\left (x-q\right )+d_{\alpha}(q-p)+p\end{align*}
Is that correct so far? Do we have to substitute the rotation matrices $d_{\alpha}$ and $d_{\beta}$ ? Or is there an other way to continue?
:unsure:
Hey mathmari!
It looks correct so far. (Nod)
We want to prove that it is a rotation around some point or a translation.
So let's assume that it is a rotation with some angle $\phi$ around point $r$.
Then we should be able to equate what you have so far to this unknown rotation. 🤔
Can we find $\phi$ and $r$ in that case? 🤔
From the equation so far we have that we subtruct from $x$ the vector $q$, then we rotate by $\alpha$ and then again by $\beta$ then we add the vector $d_{\alpha}(q-p)+p$.
So... the angle is $\alpha+\beta$, right? But the point? Is the rotation around $q$ since we subtract it at the beginning? But shouldn't we add the same vector at the end as we subtract it at the beginning? :unsure:
mathmari said:
From the equation so far we have that we subtract from $x$ the vector $q$, then we rotate by $\alpha$ and then again by $\beta$ then we add the vector $d_{\alpha}(q-p)+p$.
Yep.
So we should set up an equation. 🤔
Yep.
So does it have to hold that $d_{\alpha}(q-p)+p=q$ ? :unsure:
Nope. (Shake)
We should set up the full equation.
The argument to $d_{\alpha+\beta}$is not supposed to be $x-q$. Instead it should be $x-r$ for the as yet unknown center of rotation $r$. 🤔
Nope. (Shake)
Ah you mean to write $d_{\alpha}d_{\beta}\left (x-q\right )+d_{\alpha}(q-p)+p=d_{\phi}(x-r)+r$ ? :unsure:
Yep. (Nod)
Yep. (Nod)
I thought to do
\begin{align*}d_{\alpha}d_{\beta}\left (x-q\right )+d_{\alpha}(q-p)+p&=d_{\alpha}d_{\beta}x-d_{\alpha}d_{\beta}q+d_{\alpha}q-d_{\alpha}p+p\\ & =d_{\alpha}d_{\beta}x-d_{\alpha}d_{\beta}q+d_{\alpha}d_{\beta}d_{\beta}^{-1}q-d_{\alpha}d_{\beta}d_{\beta}^{-1}p+p\\& =d_{\alpha}d_{\beta}(x+d_{\beta}^{-1}q -d_{\beta}^{-1}p)+
d_{\alpha}d_{\beta}q+p\\& =d_{\alpha}d_{\beta}(x-d_{\beta}^{-1}( p-q))+
d_{\alpha}d_{\beta}q+p\end{align*} but that is still not in the desired form. :unsure:
Suppose we solve the equation for $r$? 🤔
A rotation is in the form $d_{\phi}(x-r)+r=d_{\phi}x+(u_n-d_{\phi})r$ so in this case it must hold \begin{align*}&d_{\phi}=d_{\alpha}d_{\beta} \\ &(I_n-d_{\phi})r=-d_{\alpha}d_{\beta}q+d_{\alpha}q-d_{\alpha}p+p \Rightarrow (I_n-d_{\alpha}d_{\beta})r=-d_{\alpha}d_{\beta}q+d_{\alpha}q-d_{\alpha}p+p \\ & \Rightarrow r=(I_n-d_{\alpha}d_{\beta})^{-1}\left (-d_{\alpha}d_{\beta}q+d_{\alpha}q-d_{\alpha}p+p\right )\end{align*}
Itholdsthat $d_{\alpha}d_{\beta}=d_{\alpha+\beta}$.
Then we have a rotation around the point $(I_n-d_{\alpha}d_{\beta})^{-1}\left (-d_{\alpha}d_{\beta}q+d_{\alpha}q-d_{\alpha}p+p\right )$ with angle $\alpha+\beta$. We have a transltion if $d_{\alpha}d_{\beta}=I_n$, then \begin{equation*}d_{\alpha}d_{\beta}x-d_{\alpha}d_{\beta}q+d_{\alpha}q-d_{\alpha}p+p=x-q+d_{\alpha}q-d_{\alpha}p+p=x+\left ((d_{\alpha}-I_n)q-(d_{\alpha}-I_n)p\right )=x+(d_{\alpha}-I_n)(q-p)\end{equation*}
Then we have a translation about $(d_{\alpha}-I_n)(q-p)$. Is that correct? Do we have to consider the case that we have both translation and rotation? Or do allconditions must hold simultaneously in that case? :unsure:
Put otherwise, we've found that if $I_n-d_\alpha d_\beta$ is invertible, that we have a rotation around a point.
And if $d_\alpha d_\beta=I_n$, that we have a translation.
If there is another possibility, it must be when $I_n-d_\alpha d_\beta$ is not invertible. Note that it isn't in the case of a translation.
Are there such cases? 🤔
