The region within circles r=cosθ and r=sinθ
  • Thread starter mrcleanhands
  • Tags
    Circles
In summary, the task is to use a double integral to find the area of the region enclosed within the circles of r=cosθ and r=sinθ. The region is first found in polar coordinates, with r values ranging from 0 to cosθ and sinθ respectively, and theta values ranging from -π/2 to π/2 and 0 to π. The common region is found to be 0≤θ≤π/2. To determine the outer curve, it is noted that r goes from 0 to sinθ from -π/4 to π/4, and from 0 to cosθ from π/4 to 3π/4. This can be simplified by recognizing the symmetry of
mrcleanhands
Use a double integral to find the area of the region enclosed within both circles of r=cosθ and r=sinθ
I begin by finding the region in polar co-ordinates.
For [itex]r=\cos\theta[/itex]
[itex]0\leq r \leq\cos\theta[/itex]
[itex]-\frac{\Pi}{2}\leq\theta\leq\frac{\Pi}{2}[/itex]
For [itex]r=\sin\theta[/itex]
[itex]0\leq r \leq\sin\theta[/itex]
[itex]0\leq\theta\leq\Pi[/itex]Now we find the region both of these have in common
which is [itex]0\leq\theta\leq\frac{\Pi}{2}[/itex]
For r we must find which function is the smallest and use that but [itex]\sin\theta[/itex] is greater than [itex]\cos\theta[/itex] for some portion and smaller for another so not sure what to do here.
Remember, r goes from r = 0 to r on the outer curve for your region. Do you see that the "outer curve" of your region is a 2 piece formula? You have to set up two integrals, unless you use some shortcut like symmetry.
If you were to look at a graph (these are circles) you would see that from [itex]\theta= -\pi/4[/itex] to [itex]\pi/4[/itex] r goes from 0 to [itex]sin(\theta)[/itex] while from [itex]\theta= \pi/4[/itex] to [itex]3\pi/4[/itex], r goes from 0 to [itex]cos(\theta)[/itex].
Ahh ok I see. I wouldn't have been sure that they are symmetrical without first looking at the graph...
Related to The region within circles r=cosθ and r=sinθ
1. What is the equation for the region within circles r=cosθ and r=sinθ?
The equation for the region within circles r=cosθ and r=sinθ is x^2 + y^2 <= cos^2θ and x^2 + y^2 <= sin^2θ.
2. What is the shape of the region within circles r=cosθ and r=sinθ?
The shape of the region within circles r=cosθ and r=sinθ is a crescent moon or a circular annulus.
3. What is the area of the region within circles r=cosθ and r=sinθ?
The area of the region within circles r=cosθ and r=sinθ is π/4 or approximately 0.785 square units.
4. How can the region within circles r=cosθ and r=sinθ be graphed?
The region within circles r=cosθ and r=sinθ can be graphed by plotting the points (cosθ, sinθ) and (sinθ, cosθ) on a Cartesian plane and connecting them with a curve.
5. What is the significance of the region within circles r=cosθ and r=sinθ?
The region within circles r=cosθ and r=sinθ represents a special case in polar coordinates where the radius is equal to the sine or cosine of the angle. It has applications in geometry, physics, and engineering.
