Mohankpvk
- 102
- 3
On the internet, I found two different explanations for lift force.
In one of the explanations, bernoullis equation was applied between the stream flowing under and the stream above the aerofoil(the stream above moves faster and so less pressure than the lower).
The other explanation says Bernoulis principle cannont be applied between two different streams.This explanation says that the curved path is the reason(for any mass to move along a curved path, centripetal acceleration is needed).The centripetal acceleration is given to the stream by the pressure difference (less pressure on the inside of the curve than on the outside).In this case only one of the two sides of the foil(either above or below) was analysed at a time.
Which among these would be the right explanation for lift?
