The role of information in gravity - ( article - food for Fra)
In summary, Spaans argues that particle-specific information on energy-momentum affects the strength of gravity, leading to a form of gravity with no free parameters, preservation of local Einstein gravity, and 5 times stronger accelerations on galaxy scales. This idea is based on the concept of the "Information postulate" which suggests that gravity is not imposed on individual observers as an exterior rule, but rather it is imposed on them by the information that is necessary to realize specific gravitational dynamics. However, his attempt to explain this idea lacks clarity and does not fully account for the physical meaning of "information."
MTd2
25
http://arxiv.org/abs/0903.4315
Authors: M. Spaans
(Submitted on 25 Mar 2009)
Abstract: It is argued that particle-specific information on energy-momentum affects the strength of gravity. This form of gravity has no free parameters, preserves Einstein gravity locally and predicts 5 times stronger accelerations on galaxy scales.
Thanks for the food :)
On first reading I have to say that brief and simple as it is, his reasoning is not clear to me. In particular his somehow obvious notion of "information" made me check if today is april 1, but it's not. I must be missing something. It seems that he is somehow counting properties and uses that count as a information measure, but then I don't understand his motivation to relate it to Einsteins equation.
I could use my imagination to speculate about a connection between gravity and information but before doing that I probably need to read the papers he refers to and see if that context makes it more clear. Perhaps he is assuming that the reading is tuned into reasoning he performed in past papers.
I'll try to find them and see if it helps.
/Fredrik
I skimmed the paper again, and skimmed his other paper in ref 3, and my total impression is that his research interest lies into understand cosmological problems, such as the acceleration and dark energy problems. And in that context, a possible revision of GR at large scale to help solve the dark energy seems like a clear possibility. So far so good.
But at least from my point of view, the suggested exact implementation of his conceptual idea seem to be a totally wild conjecture. Some plausible reasoning to provide the reader with some confidence in this conjecture would have been nice. If it's supposed to be there, I don't see it.
So disregarding the exact form of this conjecture, perhaps one can try to see what possible logic there is behind the conceptual general part he calls the "Information postulate" (IP), which at least seems to be possibly interesting.
As a background, he takes the example of the elevator analogy, and notes that the balancing needed to maintain the exact right acceleration to be equivalence to a gravity field, requires the rocket operator to be informed about how to tune the engine. Without this information the equivalence comparasion can not be physically realized. And also without this information, any observer is destined to free-fall.
As a way to extend the Equivalence principle, his "Information postulate":
Spaan said:
...every observer is perfectly able to free-fall through space-time under the influence of gravity, which suggests that some form of information is available to tell each observer how to move individually. Therefore, one is lead to the tempting assertion that gravity is not imposed on individual observers as an exterior rule, but that it is imposed on them by the information that is actually necessary to realize specific gravitational dynamics.
So what does this mean? Here is an attempt to reinterpret this.
Spaan said:
...every observer is perfectly able to free-fall through space-time under the influence of gravity, which suggests that some form of information is available to tell each observer how to move individually...
Informationwise, I tend to think of the geodesics as a result of the observers LACK of information about it's own global environment. The geodesic is then somehow the result of the observer doing a kind of random walk, where the feedback he continously gets from it's environment, slowly curving this path. The deformation is as I see it the result of a least speculation principle.
Thus the geodesic would then IMHO, better we described as the result of an evolving inside observer, randomly walking in an environment which is uncertain to him. The curved path is what a third observer would see. But I think what he says that the reason it's curved is not because there is an external constraint to guide him, but rather it's the lack of information that causes the inside observers random walk to become curved.
So the best of my understanding, would suggest that what Spaan refers to as "information is available to tell each observer how to move individually" is rather the feedback of the actions carried out. Which can be though of as infinitesimal corrections to his information, the correction of the information is what slowly causes the curved path. The inertia implied in minimum speculation, implies that that information is changing only slowly, in a "conservative way"
In this way, gravity is the result of the process of environmental feedback to an observer beeing forced to act, (do a random walk) in an environment based on incomplete information. Random walk here, is my metaphor for playing a game, place your bets to the best of your infromation, and let the feedback from the game, suggest howto revise your information. During the game, your information is deforming. Of course it remains to separate from the general abraction of information, what degrees of freedom that constitue spacetime.
This could possibly be what he means with this:
Spaan said:
Hence, under the IP, it is the insufficiency of non-gravitational information to define particle dynamics that imposes gravity.
If that is so, I think he is onto something, but I can't see how his simple attempt to account for this can be satisfactory. As I see it, it is far more involved. I think such a deep idea has far greater potential than his simple treatise admits.
Clearly the physical meaning of "information" here is paramount. Which he also admits in the paragraph where he says
Spaan said:
This is a good point to be more precise about information.
And from that point on I can't stretch myself to see that his attempt at beeing precise is sufficient. I still wonder if I missed something? As I see it, I would combine this idea with an emergent spacetime, and thus hopefully Einsteins Equations (with possible corrections) should follow from a fundamental reconstruciton. Instead he suggests a mystersious patch onto the existing equation, I do not follow that logic. It all looks to me like a completely wild conjecture. A bit too wild, even though his basic motivation seems interesting.
I agree though that the information does matter, and most probably Einsteins equations when we understand how it emergens as per this logic, will get corrections and some of these will involve the third observers own complexity scale. What he suggest might be something possible, but I would expect a serious implementaiton of this idea to be much more involve, and pretty much involved a fundamental derivation of Einsteins equation, which would be emergent.
I suspect that his prediction here are just a toy argument, to show the possible potential of the information postulate, while a proper implementation is left open.
/Fredrik
Moar food:
http://arxiv.org/abs/0903.5082
Quantum Darwinism
Authors: Wojciech Hubert Zurek
(Submitted on 29 Mar 2009)
Abstract: Quantum Darwinism describes the proliferation, in the environment, of multiple records of selected states of a quantum system. It explains how the fragility of a state of a single quantum system can lead to the classical robustness of states of their correlated multitude; shows how effective `wave-packet collapse' arises as a result of proliferation throughout the environment of imprints of the states of quantum system; and provides a framework for the derivation of Born's rule, which relates probability of detecting states to their amplitude. Taken together, these three advances mark considerable progress towards settling the quantum measurement problem.
Related to The role of information in gravity - ( article - food for Fra)
1. How does information play a role in gravity?
The concept of information in relation to gravity is still being studied and debated by scientists. However, some theories suggest that information is a fundamental aspect of the universe and is closely tied to the force of gravity. Information is believed to be encoded in the fabric of space-time, influencing the behavior of matter and energy and ultimately shaping the force of gravity.
2. Can information affect the strength of gravity?
According to some theories, yes. The amount and type of information present in a particular area of space-time can influence the strength of gravity in that region. This is because information is thought to be a fundamental aspect of the universe and can interact with matter and energy to create the force of gravity.
3. What role does quantum information play in gravity?
Quantum information, or the information carried by particles at the quantum level, is thought to have a significant role in the force of gravity. Some theories suggest that quantum information is the key to understanding the relationship between gravity and other fundamental forces, such as electromagnetism and the strong and weak nuclear forces.
4. How does information relate to the concept of gravity as a curvature of space-time?
The idea of gravity as a curvature of space-time is closely related to the concept of information. According to this theory, information is encoded in the fabric of space-time, which is bent or curved by the presence of matter and energy. This curvature then determines the path of objects in space, creating the force of gravity.
5. What are the implications of the role of information in gravity?
The implications of this idea are still being explored by scientists. Some theories suggest that understanding the role of information in gravity could lead to a more unified understanding of the fundamental forces of the universe. It could also potentially lead to breakthroughs in technologies such as quantum computing and space travel.
  • Beyond the Standard Models
11K
17K
