The role of phonons in momentum conservation
In summary, in an indirect transition, the momentum of the electron and hole stays the same, but the crystal momentum changes due to the interaction with phonons. This change in crystal momentum is compensated by the change in crystal momentum of the phonons. This is because phonons carry crystal momentum, which is different from regular momentum. The true momentum of the electron is not important in this context, as it is not in a momentum eigenstate. The lattice itself can also absorb momentum, making momentum conservation a trivial issue.
hokhani
483
In an indirect transition from the valence band maximum to conduction band minimum, the momentum of electron and hole would not change but the crystal momentum would change and this change is supplied by phonons.I have two questions here:
1) phonons don't carry momentum so how they can transfer their momentum to the crystal?
2) phonons are part of the crystal. why do we separate their momentum from crystal momentum?
Phonons don't carry momentum but they carry crystal momentum which are two completely different things.
Ok, but crystal momentum's change is sum of electron momentum's change and momentum change of the crystal;Ok? If yes, in the explained situation electron momentum is not changed so the momentum of crystal must be changed by phonons!
In an indirect transition, the electrons crystal momentum changes this is compensated by a change of crystal momentum of the phonon.
I don't see any problem here.
The true momentum of the electron doesn't interest anyone in that context, as it isn't in a momentum eigenstate anyhow.
Yes, But what I meant was the mean value of true momentum of electron which is "mass of electron times its group velocity".
As I already explained in another thread, the lattice itself (as opposed to the phonons) can take up arbitrary amounts of momentum, so momentum conservation is always trivial.
Related to The role of phonons in momentum conservation
What is the definition of phonons?
Phonons are quasiparticles that represent the collective motion of atoms in a crystal lattice. They can be thought of as a measure of the vibrational energy of the lattice.
How do phonons contribute to momentum conservation?
Phonons are responsible for carrying momentum in a crystal lattice, allowing for the conservation of momentum in certain physical processes.
Can you give an example of how phonons affect momentum conservation?
One example is in the scattering of electrons by phonons in a crystal lattice, where the momentum of the electron is transferred to the phonon and vice versa, ensuring overall momentum conservation.
Are phonons always involved in momentum conservation?
No, phonons are only involved in momentum conservation in systems with a crystal lattice, such as solids. In other systems, other quasiparticles or mechanisms may be responsible for momentum conservation.
How are phonons related to other conservation laws, such as energy conservation?
Phonons are closely linked to energy conservation as they represent the vibrational energy of the crystal lattice. In processes involving phonon scattering, both momentum and energy are conserved.
  • Atomic and Condensed Matter
