songoku
- 2,376
- 351
1. In an equilateral triangle ABC, a line segment is drawn from each vertex to a point of the opposite side so that the segment divides the side in the ratio 1:2, creating another triangle DEF.
a. What is the ratio of the area of the two equilateral triangles?
b. Check the ratio of the areas for different ratio of side (1:n, pick your own value of n)
c. By analyzing the results above, conjecture a relationship between the ratios of the sides and the ratio of the areas of the triangles
d. Prove this conjecture analytically
e. Does this conjecture hold for non-equilateral triangles? Explain
2. Do a similar construction in a square where each side is divided into the ratio of 1:2.
a. Compare the area of the inner square to the area of the original square
b. How do the areas compare if each side is divided into the ratio 1:n?
c. Prove the conjecture
3. If segments were constructed in a similar manner in other regular polygons, would similar relationship exist? Investigate the relationship in another regular polygon
Not sure
I have already stuck at first question. I guess I use equation:
Area of triangle = 1/2. a . b . sin θ
But I can't find the side of smaller triangle DEF in terms of side of triangle ABC. Please help
Thanks
