The shielding effect and effective nuclear charge
The shielding effect and effective nuclear charge are crucial concepts in understanding atomic structure. The nuclear charge refers to the total positive charge of an atom's nucleus, determined by the number of protons. However, the effective nuclear charge, which influences the attraction between the nucleus and valence electrons, is always lower than the actual nuclear charge due to the shielding effect. This effect arises in multi-electron atoms where electrons repel each other, reducing the overall attraction felt by valence electrons from the nucleus. Core electrons, located closer to the nucleus, are more effective at shielding valence electrons from the full nuclear charge due to their proximity. The effective nuclear charge can be approximated by subtracting the number of core electrons from the total number of protons, highlighting the balance of attractive and repulsive forces within the atom.
Huzaifa
OP warned about Substandard Post Quality
Whats shielding effect and effective nuclear charge?
Chemistry news on Phys.org
Per wiki: Nuclear charge is the electric charge of a nucleus of an atom, equal to the number of protons in the nucleus times the elementary charge. In contrast, the effective nuclear charge is the attractive positive charge of nuclear protons acting on valence electrons, which is always less than the total number of protons present in a nucleus due to the shielding effect.[3]
The shielding effect sometimes referred to as atomic shielding or electron shielding describes the attraction between an electron and the nucleus in any atom with more than one electron. The shielding effect can be defined as a reduction in the effective nuclear charge on the electron cloud, due to a difference in the attraction forces on the electrons in the atom.
Every electron in an atom is attracted to every proton in the atom and repelled by every other electron in that atom. Use of the term "shielding" is then somewhat misleading since a shield implies a barrier. In reality what is seen is a balancing of forces of attraction by the forces of repulsion. These forces are vector forces so core electrons (those inner electrons between the valence electrons and the protons in the nucleus) are more effective in balancing than are other valence electrons. The approximation is then to subtract the number of core electrons from the number of protons to determine the effective nuclear charge.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
