MHB The shifting of h in vertex form
  • Thread starter Thread starter miller1991
    Form Vertex
The discussion clarifies the role of h in the vertex form of a quadratic function, emphasizing that a positive h value indicates a rightward shift and a negative h value indicates a leftward shift. Participants note that the confusion arises from the interpretation of the equations, particularly how subtracting a negative affects the sign of h. It is confirmed that the value of a does not directly affect h; rather, it influences the direction of the parabola. A common misunderstanding is addressed regarding the notation and the importance of consistent case sensitivity in mathematical symbols. Overall, the thread provides insights into correctly identifying h and its implications for graph shifts in quadratic functions.
miller1991
The Role of H in the quadratic function ( vertex form)
i get that this is how its written on a graph y=(x-2)^2+k
that the graph looks as if the value of h is positive as in +2 ( however its value is actually negative)
looks like it shifted right my textbook contradicts itself
y=3(x-1)^2 +2 or y=3(x-(-1))^2 +2
a positive ie x minus a negative ie -1 equals a positive ( thus h is positive and shifts right
the value of h is +1 thus there is a right shift 1 unit
( two positives make a negative, or subtracting a negative from a positive gives a positive )
for the example
y=-1(x-3)^2
i need to know if the value of a affects the value of h
y=-1(x-(-3))^2
if a is -1
we looking at
(x-(-3))^2 gives a positive h value
then its basically
-1(3) equals a negative ( as in a negative times a positive equals a negative) thus switches h to a negative vaule
h is -3 the function shifts left
and on the graph reads as -1(x+3)^2 or w.e (not sure if that part is right)
in short a good place for me to start is understanding if A in vertex form affects the value of H in regards to the shift of h i just need to know how to solve for the value of h
like
if the question is describe the shifting of h in this function
what does h do
and does a affect the value of h
textbook question
state the value of h and describe the shifting of the function
y=3(x-1)^2 +2
answer given H = 1 and shifts right 1 unity=-(x-3)^2
answer given
h= -3 and shifts left 3 units
as far as this book indicates a is affecting the h movement THANKS GUYS ! FOR HELPING ME GET further with this
w.e info you have to help me move forward would be appreciated.so is it possible that a does not affect the shifting of h
and these
(x-(-3))^2
invisible brackets actually mean multiplication and i am not adding and subtracting here to find the value of h
Mathematics news on Phys.org
The book really doesn't contradict itself. It's that the second equation above is not the same as the first. It's merely a typo (albeit a very confusing one.) The second equation should be [math]y = 3( x - (+1) )^2 + 2[/math]. I don't know why they bothered with that.
I didn't spot any other problems except for this one.
-Dan
Addendum: You used H and h to represent a horizontal translation. Mathematics is case sensitive so H and h aren't the same. h is the usual symbol.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
