The shortest distance (gradients)
In summary, your way of taking orientation of gradient is right and exact for infinitesimal displacement.
Poetria
267
42
Function: ##f(x,y)=y^2-x^3-x##
How can we move from the point (1,1) by a distance of 0.1 by increasing f as much as possible?
What is ##(\Delta x, \Delta y)##
$$-4*\Delta x + 2*\Delta y = (-4,2) \cdot (\Delta x, \Delta y)$$
(-4,2) is ##\nabla f(1,1)##
I got:
$$(\frac {1} {\sqrt \frac {5}{0.01}}, \frac {2} {\sqrt \frac {5} {0.01}})$$
The approximate value of the function = -0.55
The exact value of the function = -0.998
Well, the vector and the exact values of the function aren't correct but I don't know why. Any hint?
The candidates points are on the circle
[tex]x=1+r\cos\theta[/tex]
[tex]y=1+r\sin\theta[/tex]
where r=0.1. Take a look at ##f(x,y)=f(\theta)## to check your result.
Likes Poetria and Delta2
Sorry for the mistake in the title. It should be 'gradient' of course.
Well, how to check it?
I have drawn a tangent computed from the gradient [-4,2].
Slope of the tangent = 2
y=2x
And I have analysed the interception points with the circle: x^2 + y^2 = 0.1
I got the result: ##(\frac {1} {(5*\sqrt{2}}), (\frac {\sqrt{2}} {5})##
The value of the function would be: -0.982828 (slightly different).
To my best knowledge the slope of the vector (-4,2) is ##\frac{2}{-4}=-\frac{1}{2}## while the circle in this problem is centered at (1,1) so it has equation $$(x-1)^2+(y-1)^2=0.1^2=0.01$$
  • Love
Likes Poetria
But I thought about a normal to the gradient (-4,2).
I.e. slope of (2,4) = 4/2
Why normal to gradient?
As far as I know the direction of greatest increase is the direction of the gradient...
But even so, I think this problem doesn't relate to gradient, it seems like an optimization problem to me with optimization function the given function and domain the circle centered at (1,1) and radius 0.1, so I feel one should proceed like post #2 suggests.
Likes Poetria
From #2 I got a result below. Your check is highly appreciated.
[EDIT]
I withdraw my calculation for your homework.
I did the following in wolfram, that is setting the maximization problem without converting to polar coordinates:
https://www.wolframalpha.com/input/?i=max+y^2-x^3-x,+(x-1)^2+(y-1)^2=0.1^2
Wolfram reports a maximum of -0.572885 at ##(x,y)=(0.914235,1.05142)##, I think this is in perfect agreement with post #2 and #7 where maximization is done in polar coordinates.
Likes Poetria and anuttarasammyak
Ok, my path is wrong then. :(
(cos(1.10715)*0.1)^2+(sin(1.10715)*0.1)^2=0.01 :(
I have to digest it.
Your (-4,2) ##\theta## =2 ##\pi##-arctan 1/2 = 2.67635
Calculation in #7 ##\theta##= 2.60152
I see they are not so much different. Your way of taking orientation of gradient is right and exact for infinitesimal displacement. r=0.1 is small but finite. So your answer should be regarded as the first approximation, but I think your teacher evaluate your answer.
FAQ: The shortest distance (gradients)
What is the shortest distance between two points on a surface?
The shortest distance between two points on a surface is known as the gradient or slope. It is the steepest descent between two points and can be calculated using the formula: Δy/Δx = (y2-y1)/(x2-x1).
How is the shortest distance (gradient) used in real life?
The concept of the shortest distance or gradient is used in various fields such as engineering, physics, and geography. It is used to calculate the rate of change in a system, determine the direction of flow in a fluid, and even in navigation systems to find the shortest route between two points.
Can the shortest distance (gradient) be negative?
Yes, the shortest distance or gradient can be negative. This indicates a downward slope or a decrease in value between two points. A positive gradient indicates an upward slope or an increase in value.
How is the shortest distance (gradient) related to derivatives?
The concept of the shortest distance or gradient is closely related to derivatives. In fact, the gradient can be thought of as the derivative of a function in multiple dimensions. It represents the rate of change of a function with respect to its input variables.
Can the shortest distance (gradient) be calculated for any type of surface?
Yes, the shortest distance or gradient can be calculated for any type of surface, whether it is a flat plane, curved surface, or even a multi-dimensional space. As long as there are two points on the surface, the gradient can be calculated using the appropriate formula.
