The sine inverse of a purely complex number
In summary, to prove that sin^{-1}(ix)=2n\pi\pm i log(\sqrt{1+x^2}+x), we can use the fact that e^{ix} = \cos(x) + i\sin(x) and the properties of logarithms to simplify the equation. The integer n can take any value. To get the other sign, we can use the property of sine function, $\sin(-x) = -\sin(x)$.
Suvadip
74
To prove that
\(\displaystyle sin^{-1}(ix)=2n\pi\pm i log(\sqrt{1+x^2}+x)\)
I can prove \(\displaystyle sin^{-1}(ix)=2n\pi+ i log(\sqrt{1+x^2}+x)\)
but facing problem to prove
\(\displaystyle sin^{-1}(ix)=2n\pi- i log(\sqrt{1+x^2}+x)\)
Help please
Re: Complex no
suvadip said:
To prove that
Help please
Can you sketch your proof ? what is $n$ ?
Hint : $e^{ix} = \cos(x) + i\sin(x)$.
ZaidAlyafey said:
what is n?
An arbitrary integer of course.
Re: Complex no
n is any integer
Let \(\displaystyle sin^{-1}(ix)=\theta\)
Then \(\displaystyle sin\theta = ix\)
\(\displaystyle cos\theta=\pm\sqrt{1-sin^2\theta}=\pm\sqrt{1+x^2}\)
Now \(\displaystyle e^{i\theta}=cos\theta +i sin\theta=\pm\sqrt{1+x^2}+i i x=-x\pm\sqrt{1+x^2}\)
Therefore \(\displaystyle i\theta=Log (-x+\sqrt{1+x^2})(Only + sign ~~considered)=2n\pi i +log(-x+\sqrt{1+x^2})\)
\(\displaystyle \theta = 2n\pi-i log(-x+\sqrt{1+x^2})\)
\(\displaystyle \theta = 2n\pi+i log(x+\sqrt{1+x^2})\)
In order to get the other sign, simply note that $\sin(-x) = -\sin(x)$.
Please a bit detailed hints
FAQ: The sine inverse of a purely complex number
1) What is the sine inverse of a purely complex number?
The sine inverse of a purely complex number is a mathematical function that gives the angle, measured in radians, whose sine value is equal to the given complex number. It is denoted by sin^-1(z) or arcsin(z), where z is the complex number.
2) Can the sine inverse of a purely complex number be a complex number?
Yes, the sine inverse of a purely complex number can be a complex number. This is because the sine function is periodic and has multiple values for a given input, making it possible for the sine inverse to have complex solutions.
3) How is the sine inverse of a purely complex number calculated?
The sine inverse of a purely complex number can be calculated using the inverse sine formula, which involves taking the inverse sine of the imaginary part of the complex number and adding it to the logarithm of the absolute value of the complex number plus the square root of one minus the squared absolute value of the complex number.
4) What is the range of values for the sine inverse of a purely complex number?
The range of values for the sine inverse of a purely complex number is between -π/2 and π/2, inclusive. However, as mentioned earlier, the sine inverse can have multiple values for a given input, so this range is not definitive.
5) What are the practical applications of the sine inverse of a purely complex number?
The sine inverse of a purely complex number has various applications in fields such as physics, engineering, and signal processing. It is used to solve equations involving complex numbers, as well as to analyze and manipulate complex signals and signals with both real and imaginary components.
