The smallest circle that two parts of a semi-circle can fit into?
In summary, the speaker made a large circular tortilla and ate half of it before putting the remaining half in the fridge. They then considered cutting the remaining semi-circle into two pieces but wondered if there was a mathematical solution for the most optimal cut. They proposed three possible solutions, including one where the cut is a straight line from the center to the edge of the original circle. They also asked if anyone could provide a demonstration and received a suggestion for a different method of cutting the tortilla in the future.
TrevorE
So, true story:
I made a large circular tortilla.
Ate half of it. Then decided to put the rest into the fridge on a smaller plate.I raised the knife to cut the remaining semi-circle in two, and then went : "Hmmmmmmmm...".
Anyway, it's in the fridge now with an approximate solution, but I'm wondering if anyone knows the mathematical one?
I'm wondering if there are 3 different optimal solutions:
1) In which the straight-line cut necessarily is from the center of the original circle to the edge. I.e. a radius.
2) In which the straight-line cut may divide the semi-circle in any possible way.
3) In which the cut is not necessarily a straight line.
Thanks in advance if anyone can offer a demonstration.View attachment 9517
Mathematics news on Phys.org
Next time, don't cut it that way. Instead, draw a circle on your pizza with radius $\frac r {\sqrt 2}$ and eat the annulus for your first half. You will be left with the smallest possible plate size.
