The solution to cos x = 2 or any number > 1
  • Thread starter Thread starter smutangama
    Cos
The discussion centers on solving the equation cos x = 2, which is impossible in the real number system, leading to complex solutions. The initial approach involved using the identity for cosine and manipulating it to find eiθ = 2±√3. The solutions derived were x = ln(2±√3) / i, which were confirmed as correct but incomplete. Further clarification indicated that the final expression should be in standard forms, resulting in x = -ln(2±√3)i. The conversation emphasizes the importance of recognizing complex logarithms when dealing with negative values.
smutangama
Generally the inverse cosine of any number > 1
cos x = 2
Obviously by putting this in a calculator, you get an error so the root has to be complex
I used the identity (e+e-iθ)/2 = cosθ
through a bit of manipulation, I came to e = 2±√3
with the solutions being x = ln(2±√3) / i
is this correct?
thanks
Watch out with your calculations, to keep them clear for yourself and others.
But, your values for x are indeed correct.
Likes 1 person
cos x = 2
is this correct?
thanks
Correct so far but you have not finished. You should be able to get the answer in eityer of the
"standard forms" a+ bi or re^{i\theta}. First, dividing by i is the same as multiplying by -i so this is x= -ln(2\pm \sqrt{3})i. Next, ln(x) where x is a NEGATIVE real number is itself complex.
True, but 2 - √3 > 0.
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 20 ·
