The Space Between Atoms -- Teaching Middle School
In summary, experts think that there is more space between atoms than the space the atoms take up themselves. Middle schoolers may not understand this concept, and may think that there is no space between particles at all.
leeone
40
Hi guys,
I know that if we consider a basic atomic model ( not considering quantum mechanics here) that an atom is mostly empty space ( 99.99999%) or something like that.
But how about the space between the atoms? Would it be appropriate to tell middle school students...8th graders... that there is more space between atoms than the space the atoms take up themselves ( in typical solids, liquids, and gases)?
Again, I want to reiterate I am introducing them to a crude marble model and speaking of only water "particles" or gold "particles", but they don't understand that "nothing" exist in the spaces between these atoms i.e they think it is filled with air.
Again, can I say that there is more space between these atoms than the space the atoms takes up themselves?
I want to reiterate these are eight graders who believe air fills the gaps between gold atoms, for example.
Astronomy news on Phys.org
You could do this computation yourself and show them how you came to the conclusion. Find a source that tells you the diameter of the atom and then compute its volume. The periodic table will give you its weight.
From there you measure the physical objects weight and volume showing the remaining space.
Or conceptually use a box of BBs in a bigger box and ask them to compute how many objects are inside based on weight and volume of the box.
I think the notion of space inside an atom vs the space between atoms will have little meaning to them.
This article says it can vary from a few nanometers to a meter or more
http://en.m.wikipedia.org/wiki/Atomic_spacing
Perhaps you could use some balloons, drop a BB in each balloon and tell them that's the nucleus. You blow the balloons up and give one to each kid and have them stand far apart and explain the notion of solids vs liquids vs gases by changing the spacing and for solids lining them up in a grid formation or bowling ball formation...
At this point I am not teaching them about the structure of the atom itself. I am more concerned with helping them understand that there is space between particles, and that this space is actually considerably large compared to the particle itself ( or is it? This is what I am trying to figure out.)
Also, since I am only using the term particle at this point, the "marble" that represents the particle includes the additional radius added by the electron orbiting the nucleus.
Only for gases, and only if the pressure is not too high.
In solids and liquids, the atoms are packed close together - about the same density you get if you throw balls in a bucket until it is full.
Atoms are not billard balls and don't have a fixed radius so this is not a perfect model, but it is not so far away from the right density.
Now you can compare typical densities of solids to the density of air to find out how much empty space there is in the air (the atoms are not the same unless you have access to liquid air, but to get an idea you can neglect this difference).
Okay. Thank You. l am doing a discrepant event where they mix 5mL of isopropyl alcohol with 5 mL of water and have them observe a total volume of less than 10mL!
Before this discrepant event, I was going to have a teacher "fact" on the board, and have them ask questions about it. My fact was going to be something about how their is empty space between particles.
Maybe I can say something like "particles in a solid have empty space between them, in a liquid even more empty space, and in a gas like air in the room even more space than the particles themselves".
The alternative is to give them a "fact" which is actually not true at all...like
" Particles is a solid, liquid, and gas can';t have empty space between them. There must be SOMETHING that fills the gaps." (This is what they actually think). Then have them do the discrepant event and address whether the teacher "fact" is true or not.
You could also do the rocks pebbles sand and water demo afterwards...
and of course the reverse demo...
for a different kind of take on things.
What if you showed them a bingo machine?
It would illustrate how atoms fill a space simply by bouncing off each other.
Unfortunately, what it would not do is disabuse them of the notion that the space between atoms is full of air.
The simplest model would be to talk about crystalline metals. Two of the most common crystal structures (FCC and BCC) have 74% and 68% of the space filled with atoms and the rest is free space (the space between the atoms). This model assumes that all atoms are spheres of equal size. Actually the most densely that you can pack spheres of equal size is 74%. This would be a very easy activity to show 8th graders. Wikipedia has a good article on this, and I like how they give some historical perspective on the packing of cannonballs (http://en.wikipedia.org/wiki/Close-packing_of_equal_spheres).
Laura thank you so much! I am definitely going to use this curing my explanation.
Also jedishrfu, I was going to do something similar during my explain portion( after the exploring with the discrepant event).
They are not completely wrong. See this video (particularly at 3:20):
Some of the particles will always be hurling through the voids like "air" particles hurling through the empty space around you.
Godparticle -
That is beside the point. Again, this is for eight graders. If you wanted to get very technical we would be talking about quantum wave functions and probability distributions, but that isn't really the point here.
One more question though, how can I convince them that air isn't between the particles in a solid.
What activity could I do with them that would challenge this notion?
I like packing of spheres. Maybe I could have them put marbles in a small beaker and have them answer questions about how this is a proper model and how it isn't?
But then again,the empty space would be filled with air :/ ...with their model.
You can show them the feather dropping in a vacuum vs the feather dropping in air explaining the reason this is so. Then ask them to draw a box with a pencil and sprinkle some dots inside. Tell them if they could use a really powerful microscope this is what they would see and have them draw a feather there with the air particles bouncing off of it slowing its descent.
Einsteins paper on the explanation Brownian motion was the first clear evidence for the existence of atoms even though they had been theorized for years. Feather dropping is another piece of the puzzle.
Thanks for the ideas guys. I think what I am going to do is have them write a poem and reflect on the concept of nothing or empty space. This will help them reflect on what it means when I keep explaining to them that their is empty space between particles. Also I do not have much time at the end of my lesson ( only a 5o minute class or so) to do another activity besides the lab.
Please let us know how the lesson turned out. I find this very interesting. The idea that there is "nothing" between the atoms can become kind of disturbing if you think about it for awhile. How many of the students really "get it?"
Okay I will definitely keep you guys updated. This lesson plan is actually part of my graduate program for my master's program. It is a prior knowledge lesson plan i am doing. (I am only a student teacher). I had students take pre-tests and interviewed individual students to get a better idea of what they were thinking. Even the high acheiving students seem to think air fills the gaps. Plenty of research shows that the students have a difficult time grasping the concept of empty space, and consistently prefer a continuous model of matter.
I am doing the lesson this Thursday, and probably the post-assessment Tuesday next week.
Hello
The problem with considering empty space to be air is just the limitations of our senses providing us with our intuitive frame of reference. It seem to me the only way to get children to "step out of their shoes" is to give them something of which they have at least some experience and have had some time to think about. One example, since many schools host TV shows of Space events and a few even have had a Q&A period for kids to ask astronauts questions. After you have filled a beaker in class maybe ask them what would be different if an astronaut performed the same action outside the capsule, or if a diver did this underwater. This might show a progression of densities that would send them in the right direction.
The Particle view of things is not intuitive and it can be a hard battle to get kids to accept that nothing is continuous - especially when we deal with most problems by assuming that it is. But kids know all about inconsistency in life - they will cope.
If you want to get the idea of 'nothing' between particles, you could challenge the automatic view about air being there by asking them if they could breathe in deep space - where there is about 1m between particles. If there were air in between then they would be able to breathe.
You problem here is that you need to convince some Adult Observer that you are getting the ideas across to the kids. This observer comes into the room with more preconceptions than the kids do (about both Science and Education). Annoying as it may seem, it may be better to go for a 'safe' approach, when you are being observed, along with a well accepted argument. It will depend on how interactive your kids are prepared to get. Once you have a good argument going then the ideas will flow - and when the Observer will be impressed. You need several different shots in your locker, in addition to your prepared resources. (OMG, I am so glad to be out of that Observation stuff. You have my sympathy).
Yeah, at least my observer is super nice though. I feel pretty prepared.
I think the "Students Questions for Purposeful Learning" technique will pique their interest with my fact (which i tell them may or may not be true and they have to come up with questions to find out whether it is true or not).
"All Mater- solids, like this table in front of me, Liquids, like the water in a cup, and gases, like the air in this room, have significant portions of absolutely empty space occupied between their particles. Gases more so than liquids, and liquids more so than Solids."
Hopefully this will spur good questions and thought. After they have the questions, I will tell them we are doing a lab (with inquiry based questions) to prove if this fact is true or not, and to answer their original questions about the fact.
Also the lab they do will throw them into cognitive dissonance as they come up with theories as to why the volume is reduced. After that, all I have to do is discuss with them their findings and see if they are happy with my teacher "Fact". During this time, I may explicitly ask what they think is between particles in the drawing of a model.
Once they are happy, we can write a poem or free write about the concept of nothing, which will let me see their thinking and give the students a chance to reflect on their understanding of "nothing" between the particles.
Thanks for the sympathy though, it is a little nerve racking.
But the idea that you have air between molecules is a contradiction of sort. Air is also made from molecules. So you will have some particles between other particles. It did not respond to the question "what is between atoms". And is not even relevant.
If everything is made from molecules (atoms), you cannot have anything between them. With the exception of other atoms (molecules).
Not talking here about fields, of course.
I think you have missed the entire point of this thread...which was to help kids understand
Yet, kids still have a hard time understanding that air isn't between air particles, no matter (pun not intended) how contradictory or ridiculous saying air is between air particles might sound.
So you cannot help them understand that having air between particles (which can happen, in porous materials) is just having more particles between the original ones and in the end must be something other than particles in between?
Did I ever say that?
I am teaching the lesson on Thursday, so we'll see how it goes.
You will get used to this sort of thing, if you stay with PF. I am as guilty as the next person of plunging into the end of a thread and missing the point.
@nasu: We are discussing how people can get wrong models - not describing a 'correct one'. Of course they're wrong - they're kids!
Yes, I got this. They are kids, sure. And I read the OP and the other posts.
I was suggesting to ask them to think what is between the air molecules. Not as a challenge but as an exercise. Addressing just one of the problems discussed above. In 8th grade kids can think and imagine things. After all, they can write poems, can't they? :)
Yes there is a lot of empty space between atoms and I hope I'm not too late, but I have a video I'd think the students would like.
It's a segment of Bill Nye The Science Guy that I think does a pretty good job at explaining this and atoms in general. It also touches on the concept of empty space in an atom.
I grew up watching this show, and this scene was my original introduction to atoms in elementary school. (I skipped school to watch it. I know, I'm bad. :) )
I'd also try to reinforce that even air is made up of atoms of Oxygen, Nitrogen, and so on, and use this to explain to them that air can't be in atoms because air is in fact made out of atoms.
I hope this helps. :)
Some kids and some things. If you are dealing with a class full of them, you cannot rely on getting messages across which involve Formal thought. (Piagettian levels ) None of this stuff is Concrete and it certainly isn't intuitive; most adults seldom engage in Formal processes and many are not capable. (PF members excepted, I am sure) It's a red letter day when the majority of a class 'get' something new as a result of being presented with and resolving cognitive dissonance.
As for Poems - it's a left brain / right brain thing, I expect and one can't assume a correlation with Science ability.
So your position is that if something can help some kids to understand a concept (but not all) that something should be avoided.
I doubt that there is any method that will work for everyone. Or that it is reasonable to expect 100% success in an average classroom, every time.
But this kind of expectations and attitude may explain why so often the science is taught by trying to avoid science as much as possible. Not only in school but in media too.
I still don't understand why is assumed that everybody will have poem ability but not scientific. Is a little inconsistent, isn't it?
The left/right brain is not a thing. Unless by thing you mean myth.
Maybe John Oliver should include this in his "How is this still a thing?" section of his show. :)
leeone said:
...an atom is mostly empty space ( 99.99999%) or something like that...But how about the space between the atoms? ...
Distinguishing the empty space in the atom from the empty space between atoms is related to defining contact of atoms:
Likes davenn
My position is that someone is asking for suitable content for a lesson that is to be 'observed'. If I, (or you) were to have a child on a one to one basis (or a small group) then things would be entirely different. I am speaking 'Teacher to Teacher' and not Physicist to Physicist. Getting too intellectual just doesn't help when you need to be seen to be getting an appropriate message across to a majority.
Otoh, if kids start to question and argue with you, there is no limit to (and no formula for) where you can go. If you have had much experience of teaching, I am surprised at your comments.
I used the left brain right brain thing in an inexact way but I do know that I have had some very high level conversations with children (and adults) about non-Scientific topics when they clearly have little inclination to Science. I have also met some very capable Scientists who are complete Philistines when it comes to the Arts. Not everyone can be Renaissance Man and school lessons cannot afford to address the few members of a class who happen to be.
On the subject of Science Lesson Quality. It is strongly influenced by a very questionable National Curriculum and by the fact than many Science Teachers just do not have the level of education to teach the subject effectively. When teachers are offered massive salaries, the profession will attract people with massive ability. Same as with any other business.
leeone said:
... but they don't understand that "nothing" exist in the spaces between these atoms i.e they think it is filled with air...
...There must be SOMETHING that fills the gaps. (This is what they actually think)...
...But then again,the empty space would be filled with air :/ ...with their model.
...Yet, kids still have a hard time understanding that air isn't between air particles...
Just wondering, how do you know this is "what the kids think"? I'm not sure I ever thought that.
  • #31
We listen to them and read what they write. Hours of marking can be useful.
And the majority of adults share their ignorance, too,
  • #32
You are right, I don't have experience in teaching at that level. I am just trying to understand or explain the bad perception of science encountered in students engaged in introductory physics courses in college or university.
I can just try to remember how me and my colleagues were in grade 8 and I don't feel that this kind of question or argument would have been too far fetched. But it is a (too) long time ago.:) I suppose my perception is distorted. Because I don't think the kids were intrinsically different then than now.
So you can reasonably expect that every child in an average 8th grade class to be able to write a poem, on a specific theme? I am not challenging this, just asking.
I don't have experience with these kids, as I already mentioned.
But I could not do it even now, and even less in grade 8. So how is that asking them to do this is not considered a bad practice? If I were in that class I would feel really frustrated.
No doubt there are differences in aptitudes and skills. I did not question this.
I was just a little unhappy about assuming that poetry is something that everybody has, somehow naturally, whereas some science related thinking is something rare, special or weird. Maybe is a self-enhanced perception due (at least in part) to media.
I agree with all this. :)
  • #33
As you are the sort of person who accesses PF then I am not surprised you weren't too challenged with any subject that you could 'warm to' at school. When I was in teacher training, an albeit rather cynical, woman teacher said (in an offhand manner) "Don't forget, Andrew, 'average' is 'thick'. It did take a long time to get used to the fact that many of the kids I taught were so much less academically developed than my school contemporaries or my own children. It's easy to make assumptions about how much you say actually gets taken on board. 'Expectations' are one thing but one has to be realistic - despite what the politicians (who want votes) say.
I wasn't the one who brought up Poetry, btw. :rolleyes: I do know that I had a period in my student life when I bought a number of poetry books and actually read them all (still do, ammof). Most of my scientific chums give me a strange look if I ever tell them. There are definitely two cultures for many people. (I don't mean PF and the rest)
  • #34
Well, reading poetry is one thing. I do it too sometimes, with some poems and specific poets. :)
Writing is what I was talking about. I know you did not bring it in. I just mentioned as something that bugged me reading the discussion.
I also enjoy music but I never wrote a symphony.
As an unrelated topic, I feel that is more likely that a scientific minded person to be interested in music, arts, literature (even poetry) than having a "right brained" ( ;) ) one to be interested in anything that may smell of science or math. I wonder why. If it's intrinsic to the mind or is biased by media and environment. Isn't considered cool to be ignorant of science or even shameful sometimes not to be? Is this maybe partly due to the education system too? I think that at early ages kids consider science cool. And then during the teen years something happens.
But this is way off topic. Sorry.
  • #35
Yes - off topic and we are on countdown for being moved or in trouble. But I am aware that most teachers of non-Science subjects have totally no clue about there subject. Otoh, a number of my Science colleagues read novels, read history and politics, go to concerts and play music. Science is the new Renaissance, I think.
  • Quantum Physics
  • Atomic and Condensed Matter
  • Other Physics Topics
  • Electromagnetism
