The spectrum of the blue part in a candle flame
In summary: Yes, you can find out the photon energy the way that you cite, but why that wavelength, and not 670 nm? Why are all of these spectral lines discrete? What is it about the energies of atoms and molecules that are so different from what we ar used to for automobiles, cats, and footballs?
Kamakiri
In the spectrum of the blue part in a candle flame, there’s a violet emission at 432 nm due to excited CH* molecules (chemiluminescence). Why 432? Why not 400 or 500? There are emissions at 436, 475 and 520 nm too. Why these numbers?
2. The attempt at a solution
Is it because the energies of the photons emitted correspond to these wavelengths, as E = hc/λ?
Why do the Balmer lines in the Hydrogen spectrum have the wavelengths that they have? If you know the answer to that question, you know why CH* emits at the wavelengths that it does.
I read about Balmer lines. The H-alpha spectral line of hydrogen gas is red, since the energy of the photons emitted correspond to 656.3 nm, as E = hc/λ. Is that right?
Related to The spectrum of the blue part in a candle flame
1. What causes the blue color in a candle flame?
The blue color in a candle flame is caused by the presence of carbon particles that are not fully combusted. These particles emit a blue light when heated, giving the flame its blue hue.
2. Why does the blue part of the flame appear at the bottom?
The blue part of the flame appears at the bottom because it is the hottest part of the flame. As the flame rises, it cools down and the blue color fades, giving way to the yellow and orange colors.
3. Can the blue part of the flame be used for heating or cooking?
No, the blue part of the flame is not suitable for heating or cooking as it is the hottest part of the flame and can easily burn food or objects. The yellow and orange part of the flame is more suitable for heating and cooking as it is cooler and produces less heat.
4. Is the amount of blue in a candle flame affected by the type of wax used?
Yes, the amount of blue in a candle flame can be affected by the type of wax used. Waxes that contain higher amounts of carbon, such as paraffin wax, will produce a bluer flame compared to waxes with lower amounts of carbon, such as beeswax.
5. Why does the blue part of the flame sometimes flicker or disappear?
The blue part of the flame can flicker or disappear due to changes in air flow or temperature. If there is not enough oxygen present, the carbon particles will not be able to fully combust and the blue color will be less prominent. Similarly, if there is a sudden gust of wind or a change in temperature, the distribution of heat in the flame can change, causing the blue color to flicker or disappear.
  • Classical Physics
  • Other Physics Topics
14K
