The speed of a metal wire on two rails with a magnetic field
In summary, the problem is trying to understand how a battery powers a wire and why the wire moves in a particular direction.
knowone
I tried to understand the problem b) and c).[/B]
Faraday's law: ∇xE = - ∂B/∂t
emf ε = Bdv
Force : F =ma, Lorenz's force F=q(vxB) ==> ma = IdB
Power : power of battery = εI, mechanical power of the wire = Fv
I think I solved a), where the magnetic force on the wire is F = IdB = ma and the speed v = at = IdBt/m.
I'm now tried to understand b) and c). First, I assume the initial speed is 0 at t=0 when the generator is replaced by a battery. The battery's power is εI, and it must be equal to the power consumed by the wire which is Fv = IdBv. Then the speed of the wire is v = ε/dB.
Also using Faraday's law I get to the same conclusion : ∇xE = - ∂B/∂t >>> ε = -∂(flux)/∂t = Bdv
It doesn't feel natural. The battery is connected at t=0, and in no time there the wire goes at speed v=ε/dB? So I think it is nonsense. But I don't know where I choose a wrong way. Help me please.
I guess the answer to c) is that the current has to be 0, because when the terminal speed has been reached, there is no acceleration, then no force F=IdB=0. Am I right at this?
In part (a), you cannot use ##v=at## because the acceleration is not constant. As the bar accelerates, the current ##I## is also not constant, but depends on the velocity which depends on time. You need to solve a differential equation for part (a). Start with Newton's 2nd Law in the form $$m\frac{dv}{dt}=IB~d$$and then use Faraday's Law to find ##I## in terms of ##v##. Put that back in Newton's 2nd Law and solve.
How do you figure? The variable "v" cancels out in the equation.
On edit: Ooops! I meant part (b) in what I wrote above, not part (a). Part (a) is correct because the rails are connected to a constant current generator.
Perhaps this thread is similar to (b) and (c) questions in your problem:
https://www.physicsforums.com/threa...-inside-a-magnetic-field.952728/#post-6036839
In your problem (questions (b) anc (c)) there are a force due the constant potential ##\varepsilon##. In the above link the force is due to a constant gravitational potential near the Earth surface. Is a little bit different but I think above thread can help you.
kuruman, I've have been thinking about this problem from yesterday because it is hard. I don't know if in the (a) question there are a variable electric potential that compensates ##\varepsilon_inducc## and then Intensity really is a constant. I don't know.
Edit.
Also it is important the direction of circulation of Intensity, because the bar must be moved to the left in the picture.
alejandromeira said:
kuruman, I've have been thinking about this problem from yesterday because it is hard. I don't know if in the (a) question there are a variable electric potential that compensates εinducc\varepsilon_inducc and then Intensity really is a constant. I don't know.
I retracted my statement on edit. Part (a) is correct.
Why? The direction of the field is shown in the figure, but without knowing which way the battery is connected, one cannot figure out the direction of the velocity.
I says about the direction o velocity because the diagram, if the bar moves to the right it will crashes whit the generator. Ok. if the supports wires are so long this is not important.
knowone needs to calculate ##\varepsilon_{inducc}## that is related with ##v## (when he applies Faraday's Induction law). After that I think that he can try:
$$\varepsilon -\varepsilon_{inducc}=I·R$$
Then knowone can get Intensity, and put it into the movement equation that you has wrote above.
Then he will need to solve the differential equation.
Please if there are some mistake say me it. In my work problems do not are so hard.
Your reasoning is correct. Let's wait and hear what @knowone has to say.
The power of the battery is εI and it equals Fv=IdBv. Thus εI=idBv and v= ε/dB
I solved these equations:
εbatteryinduced =IR, εinduced = vdB, and m(dv/dt)=IBd
Then I= (εbattery-vdB)/R, thus m(dv/dt)=Bd((εbattery-vdB)/R).
Using differential equation, v(t)=A(1-e-λt), where A = -εbattery/d2B2 and λ = d2B2/mR
Here we added a arbitrary constant R. I'm reluctant to use it because there is no specification about any resistance of the circuit.
If we are allowed to use the solution v(t), then what will be the time when the system arrives at equilibrium?
You do need R to express v(t). I believe it should have been given by the problem. Your expression for v(t) = A(1-e-λt) is correct. Clearly A is the terminal speed which should be positive. You can see that from the differential equation. At terminal speed, dv/dt = 0. What do you get when you solve for v on the right side to get the terminal speed?
The time will be mathematically infinite but the problem is not asking for it.
FAQ: The speed of a metal wire on two rails with a magnetic field
What is the purpose of studying the speed of a metal wire on two rails with a magnetic field?
The purpose of studying the speed of a metal wire on two rails with a magnetic field is to understand the principles of electromagnetism and how it affects the motion of conductive materials. This knowledge has practical applications in fields such as engineering and physics.
How does the magnetic field affect the speed of the metal wire?
The magnetic field exerts a force on the charged particles within the metal wire, causing them to move in a circular motion. This motion, in turn, affects the speed of the wire as it travels along the rails.
Can the speed of the metal wire be controlled by changing the strength of the magnetic field?
Yes, the speed of the metal wire can be controlled by changing the strength of the magnetic field. The stronger the magnetic field, the greater the force exerted on the charged particles and the faster the wire will move.
What factors can affect the speed of the metal wire in this setup?
The speed of the metal wire can be affected by various factors such as the strength of the magnetic field, the length and thickness of the wire, the material of the wire, and any external forces acting on the wire.
How is this setup used in real-world applications?
This setup is commonly used in devices such as electric motors and generators, where the motion of the metal wire in a magnetic field is converted into electrical energy. It is also used in particle accelerators and maglev trains, where the speed of the metal wire is crucial for their operation.
