The Speed of Light and of Galilean Relativity - Comments
In summary, the speed of light is not just the speed of electromagnetic waves, but determines the causal structure of spacetime. Also, the Poincare symmetries and dynamics of special relativity can be 'contracted' by sending c to infinity (for the underlying Lie algebras this procedure is known as Inönü-Wigner contraction). This opens up the lightcones of spacetime and gives you absolute time and a Galilean spacetime structure (i.e. the Galilei-group).
klotza
Insights Author
113
klotza submitted a new PF Insights post
The Speed of Light and Galilean Relativity
Continue reading the Original PF Insights Post.
Likes m4r35n357, Sorcerer, Ronald Hamilton and 3 others
A clear way for me to look upon this stuff, is the idea that the speed of light c is not 'just' the speed of E.M-waves, but determines the causal structure of spacetime. Also, the Poincare symmetries and dynamics of special relativity can be 'contracted' by sending c to infinity (for the underlying Lie algebras this procedure is known as Inönü-Wigner contraction). This opens up the lightcones of spacetime and gives you absolute time and a Galilean spacetime structure (i.e. the Galilei-group).
Why is this a nice view? Well, it shows that Galilean relativity and Special Relativity differ in only one (!) single aspect. They both say inertial observers are equivalent and the speed of light is the same for all inertial observers. For Galilean Relativity however, c is infinite, while for Special Relativity c is finite. This is the only difference. Kind of amazing.
Likes Battlemage! and Greg Bernhardt
In my opinion, it is best to leave the "speed of light" ' c ' as 3e8 m/s always [since light's speed is finite, even in Galilean relativity].
For this relativity-selecting speed-parameter, call it "maximum signal speed" ' c_max or "invariant speed" c_invariant. The dimensionless ratio c/c_max can then take the value of 1 for special-relativity and 0 for galilean-relativity. (In the Galilean case, the speed of light is finite, and nothing particularly special.)
Nice insight! I thoroughly enjoyed it!
Thanks!
Well, what's the speed of an electromagnetic wave which obeys Galilean symmetries? :)
Hmm, quoting is not going right. So let me repeat. Writing down a Galilei-covariant form of the Maxwell's equations gives eqn.'s similar to Newton's grav.eqn's. Hence instanteneous propagation, hence an infinite speed of light.
@klotza Nice article by the way, haven't said that yet!
Likes klotza
Hi
I was reading your article and you mentioned Fizeau's experiment to measure the speed of light using a cog wheel.
I believe it said that he shone a light some 15 km to a mirror and then it was reflected back.
I have tried to find more details about how he actually achieved this. For example, what did he use as a light source and what did he use the drive the cog wheel? Any ideas?
I have not yet been able to track down any proper diagrams/drawing of the actuall apparatus he used. A French university tried a while back to reproduce the experiment using a modern laser and hi-tech brushless motor and simply were not able to do the experiment.
klotza said:
see this video
near 0:56
Nice write-up. But it repeats my pet peeve that is in all the textbooks. That is some version of: “The velocity of light is c in all inertial reference frames”. It takes a really generous reading of that sentence to have it be correct. Yes, the speed of light is independent of the emitter’s speed. But the speed of a photon is not c in all inertial reference frames. In fact, it is c in only one inertial reference frame, and that is the frame of its eventual absorber / detector. That fact is right there in Einstein’s brilliant derivation of the Lorentz Transform. It just seems to me that it should be explicitly stated.
Really nice article. It's always fun to read about some of the elegant experiments that scientists designed long ago.
Maxwell's equations showing that the speed of light propagates with a constant velocity is usually used as the motivation for replacing Galilean relativity with Einstein's relativity. Where do Maxwell's equations fit into this picture? Were the scientists motivated by testing his prediction of a constant velocity of light or were they just trying to measure the speed of light as a experimental challenge?
"By considering these experiments, I think one could discount the idea that light’s speed simply adds to the speed of its source, as is required by Galilean relativity."
Hi @klotza:
I very much liked your article, but the sentence above confuses me. In the article
Wikipedia says
"Galilean relativity states that the laws of motion are the same in all inertial frames."​
Other Internet sources say the same thing in different words. For example
http://physics.ucr.edu/~wudka/Physics7/Notes_www/node47.html​
says
"Generalizing these observations Galileo postulated his relativity hypothesis: any two observers moving at constant speed and direction with respect to one another will obtain the same results for all mechanical experiments."​
What confuses me is that these definitions of Galilean relativity do not seem to imply what the quote above from your article says. Were you perhaps thinking of some other Galileo writings in which he said that light’s speed adds to the speed of its source?
Regards,
Buzz
I guess my point of view is that we already have something called "light" which we have experimentally measured its speed to be 3e8 m/s (say, in the frame of the source).
We write down a theory [on electricity and magnetism] yielding a set of PDEs, which satisfies some symmetries under (say) Galilean or Lorentz transformations.
If those PDEs have an invariant-propagation-speed that is infinite or finite but not equal to 3e8 m/s,
then why would one associate the finitely-measured-speed of light with that invariant propagation-speed?
That is to say, one would likely look elsewhere to explain "light"... There would still be the finite "speed of light" at 3e8 m/s (which wouldn't be invariant under that PDE's transformations) and an invariant-speed associated with that PDE.
If those PDEs have an invariant-propagation-speed that is finite and equal to 3e8 m/s,
then one would look further to try to associate light with that PDE.
Can you be more explicit? I wasn't aware that there was such a thing. Maxwell's equations are Maxwell's equations; they are Lorentz invariant, not Galilean invariant.
Your pet peeve seems to be wrong. There is nothing special about any particular inertial frame and the speed of light is going to be the same in any inertial frame. In fact, the special relativity "inertial frame" is generally just a substitute for a particular type of coordinate system on Minkowski space. In general, you can use any coordinate system and get the same results. The propagation of light is not tied into any particular coordinate system, it is a property of space-time.
Likes Battlemage!
I'm looking at these issues from the Correspondence Principle point of view.
I understand. In my backburner project, I am also interested in a correspondence. However, I prefer to disentangle (or at least distinguish) the many roles of "c" in relativity: Speed of light (experimental value), speed of Maxwell-type equations, invariant-speed of relativity theories, unit-conversion factor, etc... Then, when one examines a particular limit... possibly interesting features about the structure of physical theories may be better revealed.
It's along the lines of ... If we discover that the photon has a tiny but nonzero rest-mass (so that its speed is not Lorentz invariant), does special relativity fall apart? I would argue "no".
Thank you for your response. But please note carefully what I said. I did NOT say that LIGHT has speed c in only one reference frame. I said that A PHOTON has speed c in only one inertial frame, that of the eventual observer. The two observers in relative motion in Einstein's derivation of the Lorentz Transform did not / could not observe the same photon - they must observe at least two different photons. Any photon that one sees apparently arrives with velocity c relative one's own frame and not relative to any other's frame. That is right there in his derivation. I think that is also true for all the experimental verifications of SRT. I don't think one can detect a photon destined to be observed in some other reference frame. If I am wrong please let me know. But if this is correct, then it removes some of the strange and mysterious aspects of SRT for me. Thanks.
There is no need to even talk about photons in special relativity, photons are not present. You need to quantise the EM field to have photons and this is one of the most involved processes in quantum field theory. Photons are not small billiard balls. Regardless, the events of emission and detection exist in all frames - they are not coordinate dependent. Any other statement borders on misinformation.
Photons are not observed "in a frame". Frames are only different ways of putting different coordinates on the same events in space-time.
Likes Dale and Battlemage!
Some interesting points of discussion have been brought up, some of which you are discussing amongst yourselves. I will attempt to address the questions asked to me directly.
Regarding Fizeau's experiment with the cogwheel, I do not have the original source unfortunately.
"Maxwell's equations showing that the speed of light propagates with a constant velocity is usually used as the motivation for replacing Galilean relativity with Einstein's relativity. Where do Maxwell's equations fit into this picture? Were the scientists motivated by testing his prediction of a constant velocity of light or were they just trying to measure the speed of light as a experimental challenge?"
I think this is where a bit of historical rearrangement comes into it for pedagogical purposes. Many of these experiments took place before Maxwell's electromagnetic wave equation was derived. The derivation of the speed of light from Maxwell's equations shows that its speed is related to the magnetic and electric properties of the vacuum, which is interesting, especially so in the 19th century I imagine, but by themselves I don't see how they imply special relativity unless you already assume that the Lorentz transform is the right way to go between reference frames. To show that the speed is the same in all reference frames you'd have to know that, let's say, the electric attraction between two charges didn't depend on how fast they were moving with respect to some fixed frame. We now know that's true, but that information would have to be input into Maxwell's derivation somehow, which it normally isn't.
Regarding the definition of Galilean invariance, I was going with the idea that considering dynamics of ball throwers on a riverboat in the rest frame of the shore by subtracting the speed of the river would also work for people playing laser tag. I guess technically this means that Galilean relativity assumes that the Galilean transformation is the correct way to go between frames, which is an equivalent statement to the ones you pasted.
I am not familiar with Schulenberger's work.
Likes Ygggdrasil
I also very much enjoyed Alex' article.
Likes klotza
How do you explain the The Fizeau Water Experiment which demonstrates 3 inertial frames being observed having 3 different speeds relative to each other?
I am puzzled why c is defined as the velocity of light in presumably a perfect vacuum. I have read a couple of papers, which have been subject to criticisms, that c may vary via its interactions with virtual particles in space. Is there an accepted theory dealing with the effect of variation in the number densities in space through which light propagates?
Please give a specific reference. We can't answer your question without knowing what specific papers you have looked at.
There were 2 papers in the European Phys.J. in March 2016, one by M. Urban et al., the other by Leuchs and Sanchez concerning the effects of virtual particles on c. Also a book by J. Maguegeyo, Faster than the speed of light:The story of a scientific speculation, Basic Books, 2003 dealing with a higher c in the early universe.
Interesting ideas, but is there a follow-up paper showing that it's consistent with the high-precision results of standard QED, i.e., the usual radiative corrections also predicting, among other things, the vacuum polarization (or photon self-energy)? The directly observable consequences of standard QED radiative corrections are in great agreement with experiment (Lambshift of hydrogen, anomalous magnetic moment of the electron; some quibbles for the anomalous magnetic moment of the muon due to the more significant QCD corrections), and any (speculative) semiclassical model of vacuum polarization should be at least as precise as the standard QED results!
Likes Dale
exmarine said:
Any photon that one sees apparently arrives with velocity c. ... I don't think one can detect a photon destined to be observed in some other reference frame.
I would suggest you think carefully about how one could determine the speed of arrival from a single event, namely the detection of the photon.
In the section on de Sitter's experiment, there is a trivial typo, "more extreme for more distance stars" should be "more distant stars".
The possibility of the speed of the source adding to the speed of the light was proposed by Ritz, as I remember in 1908, as an alternative explanation for the Michelson-Morley experiment but I'm not sure if that was part of de Sitter's motivation.
  • #31
That would make it very hard to solve SR based relativistic rolling wheel problems, especially for solutions with "optical appearance" plots.
I tend to agree with you on this one. Have you ever wondered what happens, 'optical appearance' wise, between emission and detection in a de Sitter double star type experiment with a constant c?
The following diagram shows the photon paths, emitted from 2 rotating sources, that travel directly to an observer at c over one complete rotation. These photons exist at the time of the observation as long as the sources continued to emit during the previous complete rotation and the emitted photons were not blocked or distorted. The observation point is stationary wrt to the center of the sources plane of rotation and the photon paths are shown for the observer being at various different angles 0, 45, 60, 90 degrees to the plane of rotation. The color of the paths reflects the shift at the point of emission, for each quarter, which is then kept consistent as the photon travels through to the observer.
The speed of light is kept constant because the distance between the 2 emission start points 1,0 3,0 and the observer will always be the same regardless of the angle of the observer to the plane of rotation of the sources or the angular velocity of the sources themselves. This distance will always equal 2 * Pi * r * c/v after one complete rotation of the sources for both sources angular velocities<c.
  • #32
Usually when in wanna-be modern textbooks about classical phenomena photons are used you can as easily also use the more consistent and correct description of classical electrodynamics. What's called a "photon" in such cases is often just "ray optics" (i.e., the eikonal approximation) or just kinematics of the wave-number four-vector ##(k^{\mu})=(\omega/c,\vec{k})##. Whatever is shown in your diagrams are no photon paths. There is not even a position observable for photons. Maybe it shows "light rays" in the proper sense of the eikonal approximation, but that must not be thought of as "photon trajectories".
Likes Dale and Orodruin
  • #33
There is no need to talk about photons in this respect. Just as there is no need to talk about photons when doing classical ray optics. Actually, calling the world line of a classical massless particle in SR a "photon path" is a huge misnomer. See also the reply by vanhees71.
Likes vanhees71 and Dale
  • #34
I try to consistently use the term "light pulse" when I am talking about classical flashes of light. Especially if I am neglecting diffraction and other complications.
Likes vanhees71
  • #35
I was originally wondering how a simple geometric rotating observational model would work on galactic scales and if the apparent changes in shift along the way could appear within the optical Depth of Field of our astronomical observations.
This is how the light rays, if you like, were plotted for the 45 degree plot vanhees71. The observer is at the point where the photons arrive after one complete rotation of the source(s) and the 'light rays' shown are for the photons still in transit between the source(s) and the observer.
After one quarter of rotation photons from the start point 1,0 have traveled directly towards the observer and reach point 1, 1 while their source moves to position 4,0. Accordingly the photons emitted from start point 3,0 travel to point 3,1 while their source moves to point 2,0. All other photons emitted from their sources (heading directly towards the observer) are spread between points 4,0 & 1,1 and 2,0 & 3,1 respectively.
After two quarters of rotation the photons that arrived at point 1,1 have traveled to point 1,2, the photons at 4,0 traveled to point 4,1 and the source has moved to point 3,0 so the newly emitted photons are spread out between 3,0 and 4,1. The photons that arrived at point 3,1 have traveled to point 3,2, the photons at 2,0 traveled to point 2,1 and the source has moved to point 1,0 so the newly emitted photons are spread out between 1,0 and 2,1.
After three quarters of rotation the photons at point 1,2 have traveled to point 1,3, the photons at 4,1 traveled to point 4,2, the photons at point 3,0 traveled to point 3,1 and the source is at 2,0. The newly emitted photons are spread out between 2,0 and 3,1. The photons at point 3,2 have traveled to point 3,3, the photons at 2,1 traveled to point 2,2, the photons at point 1,0 traveled to point 1,1 and the source is at 4,0. The newly emitted photons are spread out between 4,0 and 1,1.
After one complete rotation the photons at point 1,3 have traveled to the observer at point 1,4, the photons at 4,2 traveled to point 4,3, the photons at point 3,1 traveled to point 3,2, the photons at 2,0 traveled to point 2,1 and the first source is back at its start point 1,0. The newly emitted photons are spread out between 1,0 and 2,1. The photons at point 3,3 have traveled to the observer at point 3,4, the photons at 2,2 traveled to point 2,3, the photons at point 1,1 traveled to point 1,2, the photons at 4,0 traveled to point 4,1 and the second source is back at its start point 3,0. The newly emitted photons are spread out between 3,0 and 4,1.
