The stability of diamond and graphite
In summary, at high pressures, the smaller radius and lower enthalpy of diamond outweighs the higher entropy of graphite, resulting in diamond being more stable.
pentazoid
146
Go through the arithmetic to verify that diamond becomes more stable than graphite at approximately 15 kbar
How can diamond ever be more stable than graphite, when it has less entropy
(dG/dP)=V, T and N are fixed.
dP=15 kbar.
V((diamond)=3.42e-6 m^3
V((graphite))=5.31e-6 m^3
dG(diamond)=15 kbar(3.42e-6)
dG(graphite)=15 kbar(5.31e-6)
Do my calculations above represent the the procedure I would go through to prove that Diamond is more stable than graphite?
the answer to the second question is, . A gas has a much higher entropy than any solid, but at low temperatures solids and liquids are more favorable
gibbs free energy
G= U + PV - TS
Diamond has smaller radius than graphite, therefore it has a smaller radius . U(graphite)>U(diamond) . Atoms inside graphite have the autonomy to move around its lattice, therefore it has more entropy and therefore has higher temperatures.
However, at high pressures, the entropy contribution from the lattice vibrations becomes less significant compared to the enthalpy contribution from the smaller radius of diamond. This results in diamond becoming more stable than graphite at high pressures, despite having lower entropy.
To verify this, we can look at the Gibbs free energy equation:
dG = dH - TdS
At high pressures, dH (enthalpy) is the dominant factor in determining the stability of a substance, as the entropy contribution (TdS) becomes less significant. Since the enthalpy of diamond is lower than that of graphite, diamond will have a lower Gibbs free energy and therefore be more stable.
In conclusion, the calculations you have done are a valid way to show that diamond becomes more stable than graphite at high pressures. However, the underlying reason for this is due to the enthalpy and entropy contributions to the Gibbs free energy equation.
Related to The stability of diamond and graphite
What is the difference between the stability of diamond and graphite?
The stability of a material refers to its ability to maintain its structure and properties under certain conditions. In the case of diamond and graphite, the main difference in stability lies in their molecular structures. Diamond is a 3D network of carbon atoms bonded together in a tetrahedral arrangement, making it extremely hard and stable. On the other hand, graphite has a layered structure with weaker bonds between the layers, making it less stable than diamond.
Why is diamond more stable than graphite?
The strong covalent bonds between carbon atoms in diamond make it more stable than graphite. These bonds are difficult to break, giving diamond its exceptional hardness and stability. In contrast, the weak intermolecular forces between the layers of graphite make it less stable, allowing it to easily slide and deform under pressure.
Under what conditions can graphite be transformed into diamond?
Graphite can be transformed into diamond under high temperature and pressure conditions, typically found in the Earth's mantle. This process, known as diamond formation or diamond synthesis, involves subjecting graphite to temperatures above 1500°C and pressures of 5-6 GPa. This transforms the molecular structure of graphite into the more stable arrangement of diamond.
Is diamond more stable at room temperature?
Diamond is more stable than graphite at room temperature due to its stronger bonds and more compact molecular structure. This makes diamond a more durable and long-lasting material, as it is less likely to undergo structural changes or degrade over time. However, both diamond and graphite are stable under standard conditions and can coexist without transforming into one another.
How does the stability of diamond and graphite affect their industrial and commercial use?
The stability of diamond and graphite plays a crucial role in their industrial and commercial use. Diamond's exceptional stability and hardness make it a valuable material for cutting tools, electronics, and jewelry. On the other hand, graphite's stability allows it to be used in various applications such as lubricants, electrodes, and pencils. Understanding the stability of these materials is essential in determining their suitable uses and potential for transformation into one another.
