The Strong Force on a Neutron Captured by a Nucleus
  • Thread starter Thread starter mcdowellmg
    F=ma
The discussion focuses on calculating the strong force acting on a neutron captured by a nucleus in a nuclear reactor. The neutron, initially traveling at 1.5 x 10^7 m/s, must be brought to a stop within a nucleus diameter of 0.9 x 10^-14 m. Using the equation v^2 = v0^2 + 2a(x-x0), the acceleration was calculated to be -1.25 x 10^28 m/s², leading to a force of -20.875 N when multiplied by the neutron's mass. The negative sign indicates that the force acts in the opposite direction of the neutron's initial velocity, confirming the correctness of the calculations. Understanding the direction of force is crucial in such physics problems.
mcdowellmg
A nucleus that captures a stray neutron [in a nuclear reactor, for example] must bring the neutron to a stop within the diameter of the nucleus by means of the strong force.That force, which "glues" the nucleus together, is approximately zero outside the nucleus. Suppose that a stray neutron with an initial speed of 1.5 x 10^7 m/s is just barely captured by a nucleus with a diameter of 0.9 x 10^-14 m. Assuming the strong force on the neutron is constant, find the magnitude of that force. (The neutron's mass is 1.67x10^-27 kg.)
[HINT: When the acceleration is constant, the velocity changes from vi to vf during some time interval. The average velocity over that interval is (vi + vf)/2.]
f=ma
force = mass*acceleration
also, probably one of these constant acceleration problems, since I am looking for the acceleration of the neutron.
v=v0+at
x-x0=v0t+.5at^2
v^2=v0^2+2a(x-x0)
x-x0=.5(v0+v)t
x-x0=vt-.5at^2
In those equations, v = final velocity, v0 = initial velocity, a = acceleration, t = time, and x-x0 = position on x axis.
I do not have the time it took the neutron to stop, and I am looking for the acceleration in order to determine the force.
Therefore, I used v^2=v0^2 + 2a(x-x0), which is 0=(1.5 x 10^7)^2 + 2a(0.9 x 10^-14). Solving for a, I got -1.25x10^28, and then I multiplied that by the mass 1.67x10^-27, and got -20.875.
For one, I cannot tell if I did this correctly, and two, I do not know if that should be a negative force. I do not think it is, because the neutron is not traveling left along the x axis. But then again, the neutron is traveling right on the x-axis and thus the force should be going left to bring it to a stop. I only have one shot at turning in this assignment, so I thought I would ask if someone could check over my work.
Thank you very much!
You did it correctly. The value is negative because it is in the opposite direction as the velocity, which you took to be positive. No need to think about left/right on the x axis.
  • · Replies 20 ·
14K
