'The sum of a series' question
  • MHB
  • Thread starter kris11
  • Tags
    Series Sum
In summary, if $a_n$ is chosen so that \sum_{n=1}^{\infty} a^2_{n} converges, then it follows that \sum_{n=2}^{\infty} \frac{a_n}{n^{2/3}}<\infty.
kris11
Assume that \(\displaystyle \sum_{n=1}^{\infty} a^2_{n}\) converge, and assume that \(\displaystyle a_{n}\) is non-negative for all \(\displaystyle \textit{n} \in N.\)
Determine whether the following statement is true (and prove it) or false (and give counterexample).
\(\displaystyle \sum_{n=2}^{\infty} \frac{a_{n}}{n^{2/3}}<\infty\)
Does anyone know how to do this question?
Hi kris1! Welcome to MHB! :)
Suppose we pick an $a_n$ so that \(\displaystyle \sum_{n=1}^{\infty} a^2_{n}\) converges, but only just.
Say, \(\displaystyle a_n^2 = \frac 1 {n^{7/6}}\)...
Your choice of $a_n$ doesn't contradict the convergence of \(\displaystyle \sum_{n\geq 2}\frac{a_n}{n^{2/3}}\)
Hello Kris! And a very warm welcome to the forum... (Hug)I'm not much of a series boffin, but it seems to me that if an infinite sum of squares \(\displaystyle a_n^2\) converges, then any sum of fractions of powers less than \(\displaystyle a_n^2 \) should also converge, since all you need to do is show that, say, \(\displaystyle a_n/ n^z \le a_n^2\)...
Hint: Use the Cauchy–Schwarz inequality.
Interesting enough, found the same question here before I saw this one : http://www.mymathforum.com/viewtopic.php?f=22&t=44756 :p
At least got checked that I answered correct. :D
Hi Everyone :) Thank you for all your replies :) I still haven't done this question :( I don't know what Cauchy–Schwarz inequality is, but I looked for this inequality on the internet and tried to apply it to my question but it didn't work. I also tried convergence tests but I gave up. I can do that kind of questions but when I have real numbers and I have to find limits, but for this question I need to prove given statement, which is my greatest weakness :( Please help me!
Applying CS-inequality,
$$\left ( \sum_{n\geq2} \frac{a_n}{n^{2/3}}\right )^2 \leq \left (\sum_{n \geq 2} a_n^2 \right ) \left (\sum_{n\geq 2} \frac{1}{n^{4/3}} \right ) $$
Can you prove this now?
Yeah, I think I can prove it, however I cannot use this method as I never learn it before. So far for this kind of questions I learned tests for convergence, eg ratio test, root test, integral test... etc :) So I think my teacher wants me to solve this question using these methods. But thank you very much for your replies :)
It looks like you really need the Cauchy-Schwarz inequality... in combination with the Direct Comparison Test.
If $x$ and $y$ are positive numbers then $x^2 + y^2 - 2xy =(x-y)^2 \geqslant0$, from which $xy \leqslant \frac12(x^2+y^2).$ Apply that with $x=a_n$ and $y = n^{-2/3}$ to see that \(\displaystyle \frac{a_n}{n^{2/3}} \leqslant \frac12\Bigl(a_n^2 + \frac1{n^{4/3}}\Bigr).\) Then \(\displaystyle \sum \frac{a_n}{n^{2/3}} \leqslant \frac12\Bigl(\sum a_n^2 +
\sum \frac1{n^{4/3}}\Bigr)\), and it follows from the comparison test that \(\displaystyle \sum \frac{a_n}{n^{2/3}}\) converges.
Ohh thank you! So for the first part you used Cauchy-Schwarz inequality, right? And can I prove it by using real numbers, eg for \(\displaystyle a_{n}\)=2, and n=8 ?
FAQ: 'The sum of a series' question
1. What is the sum of a series?
The sum of a series refers to the total value obtained by adding up all the terms in a sequence.
2. How do you find the sum of a series?
To find the sum of a series, you can use various methods such as using a formula, finding a pattern, or using a calculator.
3. What is the difference between an arithmetic and geometric series?
An arithmetic series has a constant difference between each term, while a geometric series has a constant ratio between each term.
4. What is the formula for finding the sum of an arithmetic series?
The formula for finding the sum of an arithmetic series is S = (n/2)(a + l), where S is the sum, n is the number of terms, a is the first term, and l is the last term.
5. How can the sum of a series be used in real life?
The concept of sum of a series is used in various real-life situations such as calculating the total cost of a purchase with repeated payments or determining the growth rate of a population over time.
