Alfredo Tifi
- 68
- 4
- TL;DR Summary
- Imagine you start from a quasi-spherical rarefied cloud of "stardust" particles with quasi-inertial random movements. After enough time you'll get a condensed body, maybe a star in the centre of mass and other external bodies. Everything would be rotating as in our Solar system.
I suppose that the principle of conservation of angular momentum holds also for a cloud of particles weekly interacting at low pressure, density and temperature. And it should be still applicable when the particles or the atoms would start condensing and forming fusion products or simply solid matter.
The principle of conservation of angular moment keeps its validity even if the condensing cloud start emitting several kinds of radiant energy or sub-atomic particles.
I also know that the only way to keep the angular moment constant while kinetic energy is dissipated uniformly (due to tidal interactions or any kind of internal friction or decay) is to enlarge the radius of rotation of the particles, or of the condensing bodies, along the rotation plane.
The symmetry changes from spherical to disc or "sombrero" type, with a very precise rotation axis.
So, there are centripetal (due to gravity) and centrifugal (due to energy loss) flows of matter.
The system becomes heterogeneous due to clashing opposite flows and local spiral movement arise out of the centre due to the local concentrations of matter.
This scenery is a fantastic example of self-organisation of matter from a randomly distributed matter, but... which is the source of the initial angular moment? It is a sort of unavoidable non-zero fluctuation of the not-exactly balanced momenta of the many particles which are moving in the cloud? Or is it a portion of a "stash" of angular momentum derived from the big-bang?
