The system shown in the figure below consists of a mass M = 4.3-kg
In summary, the system shown consists of a 4.3-kg block attached to a string over a pulley, and a 1.6-kg hanging block. The pulley is a uniform disk with a radius of 8.0 cm and a mass of 0.60 kg. To find the acceleration of each block, you can use Newton's 2nd law and solve for the tensions and acceleration by analyzing the forces acting on each mass and the pulley.
astr0
The system shown in the figure below consists of a mass M = 4.3-kg block resting on a frictionless horizontal ledge. This block is attached to a string that passes over a pulley, and the other end of the string is attached to a hanging m = 1.6-kg block. The pulley is a uniform disk of radius 8.0 cm and mass 0.60 kg.
What is the acceleration of each block?
What are the two tensions in the string?
I know that I can find the moment of inertia with I = 0.5*M*R^2
Therefore, I = 0.00192
But, I don't understand how to find the acceleration of the blocks. I know that the acceleration of each block will be the same, but I do not understand how I can find it with the given information.
Start by analyzing the forces acting on each mass and on the pulley. Apply Newton's 2nd law to each, giving you three equations. Solve those equations to find the tensions and the acceleration.
FAQ: The system shown in the figure below consists of a mass M = 4.3-kg
What is the mass of the system?
The mass of the system is 4.3 kg.
What are the forces acting on the mass?
The forces acting on the mass are the gravitational force (weight) and the normal force.
What is the acceleration of the mass?
The acceleration of the mass can be calculated using Newton's Second Law, F=ma. The net force acting on the mass is equal to its mass multiplied by its acceleration, so the acceleration can be found by dividing the net force by the mass.
How is the acceleration of the mass affected by changing the mass?
According to Newton's Second Law, the acceleration of an object is directly proportional to the net force acting on it, and inversely proportional to its mass. This means that increasing the mass will decrease the acceleration, and vice versa.
What is the direction of the forces acting on the mass?
The gravitational force acts downwards, towards the center of the Earth. The normal force acts perpendicular to the surface the mass is resting on, in this case, upwards.
