The temperature distribution on metal plate is given by
In summary, the conversation is about finding the temperature distribution on a metal plate and calculating the directional derivative in a specific direction at a given point. The first part of the problem asks for the highest temperature on the plate, which is not necessarily in the center. The second part asks for the directional derivative in an arbitrary direction, and determining the direction in which it is largest and smallest. The solution involves finding and using the gradient vector of T(x,y), and understanding the dot product to determine the directions that maximize and minimize the directional derivative. The work done so far is based on guesswork and lacks evidence of actual calculations.
hargun519
The temperature distribution on metal plate is given by...
T(x,y) = 100/x^2+y^2+1
Calculate the direction derivative in the direction of v= <1,1> at the coordinates (3,2) and at coordinate (3,2) in what direction does the increase, and then decrease most rapidly? Give a unit vector
For the first part of the problem the question asks, where is the plate hottest? I am guessing the plate would be hottest in the center. So, my general idea of this problem is that if we have a disc and then a coordinate plane on the disc, the point 3,2 is on the quadrant 1. The temperature if increasing would point down toward the origin, and then decrease point up, away from the origin.
However, i do not know if I am right, and even if i am i still really don't understand what the problem wants me to do.
They want you to find and use the gradient vector of T(x,y). The directional derivative in a direction v at a point (x,y) is given by (v/|v|).grad(T)(x,y) (dot product) for v. If you think about what the dot product means you should be able to figure out that the directions that maximize and minimize that are directions parallel and antiparallel to grad(T)(x,y).
I'm not sure that what you wrote for the temperature is what you meant. I suspect that the function is T(x, y) = 100/(x2 + y2 + 1), which is different from what you wrote. If that's the case, the highest temperature is NOT in the middle of the plate.
The first part of the problem you posted asks you to find the directional derivative of T in the direction of <1, 1>, evaluated at the point (3, 2).
The second part of the problem you posted asks you to find the directional derivative of T in an arbitrary direction, evaluated at the point (3, 2). From this you are supposed to determine the direction in which the directional derivative is largest and smallest.
So far, your work seems to be entirely based on guesswork, with no apparent evidence that you have tried to calculate anything. Show us what work (not guesses) you have done, and we'll give you a hand.
FAQ: The temperature distribution on metal plate is given by
What is the temperature distribution on a metal plate?
The temperature distribution on a metal plate refers to the variation in temperature across the surface of the plate. This can be represented by a temperature map, with different colors or shades indicating different temperatures at different points on the plate.
How is the temperature distribution on a metal plate determined?
The temperature distribution on a metal plate is typically determined through experimental methods, such as using temperature sensors at different points on the plate and recording the readings. It can also be determined through mathematical models and simulations.
What factors affect the temperature distribution on a metal plate?
The temperature distribution on a metal plate can be affected by various factors, including the initial temperature of the plate, the heat source applied to the plate, the material and thickness of the plate, and the surrounding environment.
Can the temperature distribution on a metal plate change over time?
Yes, the temperature distribution on a metal plate can change over time as the plate is heated or cooled. It can also change due to external factors, such as changes in the environment or changes in the heat source applied to the plate.
How is the temperature distribution on a metal plate used in practical applications?
The temperature distribution on a metal plate is important in many practical applications, such as in the design of heating and cooling systems, in analyzing the thermal behavior of materials, and in studying heat transfer processes. It can also be used in quality control to ensure that the temperature distribution on a metal plate meets certain specifications.
