The Tensor Algebra - Cooperstein, Defn 10.5
In summary: I don't like this notation. I would prefer to say that we have a function $$\boldsymbol{x}\colon\mathbb{N}\to\bigcup_{d\in\mathbb{N}}\mathcal T_d(V),$$ which we can think of as a sequence of tensors. But then I would define the degree of ##\boldsymbol{x}## to be the smallest index with ##\boldsymbol{x}_i\neq 0##, if it exists. Otherwise, ##\boldsymbol{x}## has infinite degree.
Math Amateur
MHB
3,998
48
I am reading Bruce N. Coopersteins book: Advanced Linear Algebra (Second Edition) ... ...
I am focused on Section 10.3 The Tensor Algebra ... ...
I need help in order to get a basic understanding of Definition 10.5 in Section 10.3 ...Definition 10.5 plus some preliminary definitions reads as follows:
In the above text from Cooperstein, in Definition 10.5, we read the following:
" ... ... An element ##x \in \mathcal{T}(V)## is said to be homogeneous of degree ##d## if ##x \in \mathcal{T}_d (V)## ... ..."My question is as follows:
How can x be such that ##x \in \mathcal{T}(V)## and ##x \in \mathcal{T}_d (V)## ... does not seem possible to me ... ...
... ... because ... ...
... if ##x \in \mathcal{T}(V)## then ##x## will have the form of an infinite sequence as in the following:##x = (x_0, x_1, x_2, \ ... \ ... \ , x_{d-1}, x_d, x_{d+1}, \ ... \ ... \ ... \ ... ) ##where ##x_i \in \mathcal{T}_i (V)##... ... clearly ##x_d## is the ##d##-th coordinate of ##x## and so cannot be equal to ##x## ... ..
Can someone please clarify this issue ... clearly I am not understanding this definition ...
Peter
stevendaryl said:
It is the disjoint union of all the [itex]\mathcal{T}_k[/itex]
Not true.
[itex]\mathcal{T}_2[/itex] = the set of pairs of vectors, which we can represent as [itex]\langle x_1, x_2 \rangle[/itex]
[itex]\mathcal{T}_3[/itex] = the set of triples of vectors: [itex]\langle x_1, x_2, x_3 \rangle[/itex]
Both very much not true.
micromass said:
Not true.
It would have been helpful if you had said what you consider to be true, instead just saying that something is not true. Why do you think it's not true? What do you think the operation [itex]\oplus[/itex] means?
Likes Math Amateur
I'm letting micromass answer your question. But my original point is correct, which is that for every [itex]n[/itex], there is a "copy" of [itex]\mathcal{T}_n[/itex] within [itex]\mathcal{T}[/itex].
Likes Math Amateur
stevendaryl said:
It would have been helpful if you had said what you consider to be true, instead just saying that something is not true. Why do you think it's not true? What do you think the operation [itex]\otimes[/itex] means?
The set of pairs, triples and so on are cartesian products. [itex]\otimes[/itex] denotes equivalence classes of them. E.g. ##(2v,w), (v,2w) \in V \times V## are different elements but the same in ##V \otimes V##. Similar for the addition. This structure transports into ##\mathcal T##. And ##0## is an element of all ##\mathcal T_k## and ##\mathcal T##. It is considered the same ##0## in all of them so the union cannot be disjoint.
Likes Math Amateur
One definition of [itex]\mathcal{T}[/itex] is that it is the "free algebra" over [itex]V[/itex].
Thanks. But in any case, [itex]\mathcal{T}[/itex] contains a copy of [itex]\mathcal{T}_n[/itex] for each [itex]n[/itex], so you can think of any element of [itex]\mathcal{T}_n[/itex] as also being an element of [itex]\mathcal{T}[/itex].
Likes Math Amateur
As far as I'm concerned I always think of stuff going on in one [itex]\mathcal{T}_n[/itex] as long as I'm not bothering with the overall properties. IMO [itex]\mathcal{T}[/itex] isn't a nice place to really do calculations in but calculations on.
Likes Math Amateur
The only use I've ever seen for mixed expressions (linear combinations of terms from different [itex]\mathcal{T}_n[/itex]) is Clifford algebra.
Likes Math Amateur and fresh_42
You don't think polynomial rings are a nice place to do calculations in? Because those are the kind of objects you get for ##\mathcal{T}##.
If ##V = \mathbb{F}##, then ##\mathcal{T}_n \sim \mathbb{F}## and ##\mathcal{T} = \mathbb{F}[X]##.
If ##V = \mathbb{F}^2##, then ##\mathcal{T} = \mathbb{F}<X,Y>##, the polynomials with variables ##X## and ##Y## that do not commute.
In general, if the dimension of ##V## is ##n##, then ##\mathcal{T} \sim \mathbb{F}<X_1,...,X_n>##.
Likes Math Amateur
Touché. I just won't write them as tensors. They are just a bit too universal. Maybe it is about getting used to. I've met tensors in complexity theory as a way to describe n-linear algorithms, as universal algebraic objects or as part of cohomology theory where it is often about calculating between the filtration.
Likes micromass
When the author writes
Cooperstein said:
An element ##\boldsymbol{x}\in\mathcal{T}(V)## is said to be of homogeneous of degree ##d## if ##\boldsymbol{x}\in\mathcal{T}_d(V)##
I'm pretty sure that's an abuse of notation. ##\boldsymbol{x}## is a function from the index set ##\mathbb{N}## to ##\bigcup_{d\in\mathbb{N}}\mathcal T_d(V)## so it cannot also be an element of ##\mathcal T_d(V)##, which is part of its range. I think he must mean
$$Image(\boldsymbol x)\subset\left(\mathcal T_d(V)-\{0_{\mathcal T_d(V)}\}\right)\cup\bigcup_{k\in\mathbb N-\{d\}}\{0_{\mathcal T_k(V)}\}$$
Or, more succinctly:
##\pi_k(\boldsymbol x)## is zero for all ##k\in\mathbb N## except ##k=d##, for which it is nonzero.
So your (@Math Amateur 's) concern is entirely correct. However, the abuse of notation in question was foreshadowed by the author in the excerpt you posted in your other recent thread on this topic. Personally, I think it best in teaching texts to defer such abuses at least until the reader has had time to get comfortable with the new concepts - eg 'by now you should be familiar enough with the concepts of direct sums that we will henceforth, where it streamlines the notation, identify homogeneous elements of such direct sums with their isomorphic images in the component spaces'. But at least Cooperstein foreshadows the abuse.
@stevendaryl in post #6 has put his finger on the identification Cooperstein is making. The sense in which there is a 'copy' is that the set of all homogeneous elements of degree ##d## form a vector subspace of ##\mathcal T## (but not a subalgebra, as the set is not closed under tensor multiplication), which is vector-space-isomorphic to ##\mathcal T_d##.
Thanks to all who have helped ...
Thanks Andrew for a complete and thorough answer to the question that was bothering me ...
Peter
Related to The Tensor Algebra - Cooperstein, Defn 10.5
1. What is the Tensor Algebra?
The Tensor Algebra is a mathematical concept used in linear algebra and multilinear algebra. It is a way of representing and manipulating linear transformations between vector spaces. It involves the use of tensors, which are multi-dimensional arrays of numbers, to perform calculations and solve problems.
2. Who developed the Tensor Algebra?
The Tensor Algebra was developed by mathematician Melvin Cooperstein. He introduced the concept in his book "Tensor Algebra and Tensor Analysis for Engineers" in 1985. His work has been influential in the fields of physics, engineering, and computer science.
3. What is Defn 10.5 in Cooperstein's Tensor Algebra?
Defn 10.5 is a specific definition within Cooperstein's Tensor Algebra. It states that a tensor is a multi-dimensional array of numbers that can be transformed by tensor operations. These operations include addition, multiplication, and contraction, and they allow for the manipulation of tensors to solve problems in linear algebra and multilinear algebra.
4. How is the Tensor Algebra used in science?
The Tensor Algebra is used in many areas of science, including physics, engineering, and computer science. In physics, it is used to represent and solve problems in mechanics, electromagnetism, and general relativity. In engineering, it is used in fields such as structural analysis and fluid mechanics. In computer science, it is used in machine learning and artificial intelligence algorithms.
5. What are some real-world applications of the Tensor Algebra?
The Tensor Algebra has many practical applications in the real world. It is used in image processing to analyze and manipulate images, in robotics for motion planning and control, and in finance for risk assessment and portfolio optimization. It is also used in medical imaging for diagnosing and treating diseases, and in geology for analyzing seismic data.
  • Linear and Abstract Algebra
