The tensor product of tensors confusion
GR191511
76
TL;DR Summary
Why is the tensor product of two tensors again a tensor?
> **Exercise.** Let T1and T2be tensors of type (r1 s1)and (r2 s2) respectively on a vector space V. Show that T1⊗
T2can be viewed as an (r1+r2 s1+s2)tensor, so that the
> tensor product of two tensors is again a tensor, justifying the
> nomenclature...
What I’m reading:《An introduction to tensors and group theory for physicists》Authors: Jeevanjee, Nadir. According to it,
a tensor is a multilinear function that eats r vectors as well as s dual vectors and produces a number...And "Give two finite-dimensional vector spaces V and W,we define their tensor product V⊗W to be the set of all C-valued bilinear functions on V*×W *..."
How do I define the tensor product of two tensors by these definition?And What the target object this tensor product acts on should look like?
GR191511 said:
Summary:: Why is the tensor product of two tensors again a tensor?
> nomenclature...
A tensor is a multilinear function, but it doesn't produce a number. Only the dual vectors if fed by vectors turn into scalars, the part with the vectors remains.
We have
so
which can be sorted to an equivalent tensor
Here is an example of a tensor, which is a bilinear function:
https://www.physicsforums.com/insights/what-is-a-tensor/
I think we can say it produces a number. If we take the usual definition of a (m n) tensor over vector space V on field F as a multi-linear function whose domain is the cartesian product of a collection of m copies of V and n copies of the dual space V*, and whose range is F, then we can say the function 'produces a number', meaning just that it maps ordered tuples of m vectors and n covectors to numbers (scalars).
If for , tensor over vector space V and field F is , it maps vectors in V ( ) and covectors in V* ( ) to a number in F, denoted by :
then the vector is and maps vectors in V ( ) and covectors in V* ( ) to a number in F, denoted by
which is equal to
In other words, to get the result from applying the product tensor, you just multiply the results of applying the two mutiplicand tensors to their respective arguments taken from the appropriate places in the input tuple to the product.
No, we cannot. You can feed the covectors, but the vectors remain vectors. is a matrix and not a number.
  • Skeptical
Likes weirdoguy
I think you are misreading the OP. 'it produces a number' doesn't say the tensor product is a number. It says that it is a function that delivers a result that is a number - ie the function's range is a space of numbers (typically or ),
We have
so
We have
so
Why can s1 covectors and r2 vectors commute with each other at the last step?
Sure, but this is definitely wrong! Except we have tensors of type .
If we have tensors with then there is no way to make go away. E.g. a tensor is - considered as a function - an algebra multiplication. Since when produces an algebra multiplication a number?
It is not that you commute the factors. It is strictly speaking an isomorphism of vector spaces, or tensor spaces if you like. An isomorphism that isn't written down as it doesn't really carry information. It's simply convenient to sort them into the scheme. And if you consider a tensor space over a vector space as an algebra with the multiplication then you have to apply this isomorphism. Loosely speaking: it doesn't matter if we are talking about length times height or height times length, although there would be a formal difference.
I don't see what the problem is! The input is vectors and one forms, the output is a number.
What number? Repetition does not make it right. Let be a vector space, and . Then is obviously a vector and not a number. However, is a tensor.
If , then is a function that produces a number, but not in case .
In this case can be viewed as an element of , so for each you get the number .
Yes, and the projection on the first coordinate is a number, too. The question was "what is a tensor" and not "what can I do to make it a number". To call a tensor a multilinear function into the scalar field is wrong. Your poor construction as an excuse is additional framework. It is as if you were saying that all vectors were covectors. This is confusing and wrong, at least in mathematics. That physicists always make vectors covectors is another subject.
A vector is a tensor, and it is neither a function nor a number.
Repetition of wrong does not change this fact.
  • Skeptical
Likes weirdoguy
This is standard in mathematics. Many define tensors as multilinear maps. It is equavalent to what you consider the only definition and cannot be wrong. It is a matter of personal prefernce.
It is also not hard to see that the space of all linear maps
and the space
are cannonically isomorphic.
and the space
It would be more accurate to say: all tensors are vectors, scalars and covectors included, than the other way around.
Mathematics distinguishes between scalars, vectors, and covectors. Any isomorphisms come afterward!
If it comes to differential forms or tangent spaces, things become complicated. is still a vector, a tangent, but it can be evaluated at a certain point which makes it a number, a slope. So some tangent vectors can be seen as functions that produce numbers, but this is not what a tensor is. It is how it can be used. That is something different.
E.g. I can write as a Lie algebra of differential operators. Its multiplication structure is a bilinear mapping which is a tensor. And although the vectors are written as differentials, the tensor itself doesn't become a number-producing machine. It produces differential operators.
To consider curvature tensors or alike, one has to set additional structures upon the tensor. It is what you make out of it, not what it is. A tensor is still a simple vector because it is part of a vector space. And vectors and covectors are different objects, mathematically.
The phrasing in the OP's book is misguiding. Not all vectors are covectors, but all covectors are vectors.
I am not sure how this relates to what I said. My point is simply that there is nothing wrong, and is often done especially in differential geometry books, to define tensors as multilinear maps. If the OP uses a book that goes that way, does it help to call it "wrong"!?
It is wrong to treat all vectors as covectors! You can do it a) the other way around, or b) do not ask a mathematician, or c) learn it wrong.
We would lead the very same discussion the other way around if I would claim that all vectors are covectors and that there is no difference between them. You bet!
I am still not sure what you mean. What do you mean by "treat all vectors as covectors"?
Sure, that is what you repeatedly and falsely claim. You need covectors to get scalars, and you claim that all parts of a tensor are covectors. Sorry, but this is still wrong. I have provided multiple examples where such a statement is obviously wrong, yet, you insist that vectors are covectors. And, no, do not say no, this is exactly what it means if you want to spit out numbers. Disguise it as you want: Covectors are vectors (but primarily not in this context where both were distinguished already in the definition of or ), but vectors are not covectors, everything else is voodoo.
Here is what I said: Given two (any number) vector spaces and over a field , the vector spaces and are canonically isomorphic. This is TRUE. Therefore one can, and one does sometimes, use the second one as a definition of the first one.
I still don't understand your obstinacy and why you are complaining about this!
Because the definition says -tensor. This means vectors and covectors.
I am complaining that you basically claim it is a -tensor, which it is not.
(I know the difference, but that doesn't become clear at all by what you said.)
A -tensor regarded as a function is a multilinear map and not into a field. It is simply wrong and misleading to state otherwise.
Your entire claims are flawed and rely on additional constructions. The part are vectors and not functions. What makes me angry is, that I know that you know you are talking bs.
  • Sad
  • Skeptical
Likes weirdoguy and martinbn
I give up. It is not my problem that you are stubborn.
  • Sad
Likes weirdoguy, fresh_42 and Gaussian97
Yep, continue to tell that all vectors are covectors. I think you should write a paper. It would a revolution in homological algebra!
I also studied tensors as multilinear maps from could you explain exactly how this implies that all vectors are covectors?
eats many independent vectors and turns them into scalars.
But what do you do with ? They remain vectors and do not map to .
If you want to map them to , then you have to make them covectors, i.e. eating vectors to turn them into numbers, or manipulate them otherwise.
Now my questions:
  • If we consider this -tensor as multilinear mapping into , why isn't it a -tensor to begin with?
  • What happened to the vectors?
  • Strassen's algorithm for matrix multiplication is a -tensor. Where does it end up in ?
  • A vector isn't a function. If we treat it as such, then we must do something, namely setting or something else, e.g. evaluating a differential form at a certain point. These cannot be viewed as automatisms. We actively turn a vector into something else, mostly into And if there is no inner product?
  • One has to be careful with infinite-dimensional spaces:
    https://en.wikipedia.org/wiki/Dual_space#Infinite-dimensional_case
No, you feed them covectors.
fresh_42 said:
Now my questions:
is canonically isomorphic to . No extra structure needed, no choice of basis needed, no nothing, no matter the dimension.
Likes weirdoguy
Mmm... Probably this is a silly question but when you say that eats many vectors, do you mean that the elements of are linear maps that eat many vectors? Otherwise, can you specify what do you mean?
I don't understand this, what I do with the elements of ? I map them to isn't this precisely what a map does?
When we talk about a map what do you do with ? Of course, you can view the action of mapping them as a "manipulation" but I don't see what is the problem.
As by say that to be able to do such a map we need to consider them covectors... I was introduced to covectors precisely as maps so are we supposed to need covectors to define covectors? Probably I'm not seeing something very trivial, but I don't understand your question.
I'm not an expert, but I'll try my best to answer your questions (although the answers have high probability to be wrong)
A tensor is a multilinear map i.e. it eats covectors and vectors and returns a number. A tensor is a multilinear map so it eats covectors and returns a number. Precisely because vectors and covectors are not the same thing, why should a tensor be a tensor?
Well, I think this is the same question as before that I don't really understand. My best answer is... They get mapped, together with the covectors, to a real number.
Well, in the same way as for you what I call tensors aren't tensors, I could just say that such a thing is not a tensor. I think that, given a map you can always create a tensor
In the other way, given an arbitrary map you can define a map
with a base of and the dual base, and sum over is implicit.
I don't know if this answers your question in some way.
Again, probably just a silly question, but why do we need to consider that vectors are functions?
The last question (which isn't actually a question) is far from my understanding, so maybe we should concentrate on finite dimensions?
Sorry if my questions are silly or I'm confounding completely different concepts.
Fresh, you seem to be thinking of a different multilinear function from what the rest of us are.
I am using the definition of a (m n) tensor over vector space V and field F as a multilinear function from to .
Given the quote above, you appear to be viewing it as a multilinear function, but a different one from me. You appear to consider the domain of the function to be but you have not explicitly stated the range. I am imagining you see the range as something like what we get if we successively reduce the matrix representation of T by each of the m input vectors. Hence the need for care in an infinite-dimensional space. The range of such a function might be , which will not in all cases be the same as . I get the sense that it is those complexities that are concerning you.
What I don't get is why you feel the need to bother with those complexities at all, since they only arise from treating the tensor as a function with domain , rather than as a function with domain .
I think you created this problem by in your first post defining as a product of vectors and covectors, ie
fresh_42 said:
We have
rather than as a function that takes vectors and covectors as inputs and delivers a scalar, which is what the OP did.
If you define it your way then you can't assume that the tensor eats covectors, but if you use the OP's (and my, and martinbn's) definition you can.
Since all the objections seem to arise from the above formula, they fall away when we reject it.
Both definitions can work and can be shown to be equivalent, up to isomorphism. They appear as respectively the 2nd and 3rd definitions in the wiki article on tensors. But the OP is using the definition as multilinear map (with scalar range), so it just introduces unnecessary confusion to use a different definition.
I don’t think anyone was saying that a vector is the same as a covector. I think what was being claimed was that a tensor can be thought of as a function that takes vectors and covectors and returns a scalar.
So in this interpretation, a tensor is not literally a vector; it is an element of not an element of
Likes weirdoguy and andrewkirk
We may have to end up appealing to Bill Clinton's (in)famous phrase " It depends on what is is". You can look at, e.g., The Real numbers from many perspectives as they have many different types of structures: 1-dimensional Euclidean Space, a Field, a Vector Space over itself, etc. and none of these somehow prevails over the others.
I think there is no need for that, since there are already a lot of textbooks on linear algebra that states what you say is "wrong". E.g. Introduction to Algebra, volume 2, by Alexei Kostirkin. And I would say it's a basic knowledge, I learned it during my first year at university! I thought that it's the standard way to define tensors. It's weird that a mathematician does not know that.
  • #31
The standard definition of tensor product of two vector spaces (perhaps infinite dimensional) is as follows. let be vector spaces (say over ) and let be a space of bilinear functions .
Define a mapping as follows
so that We have also got a bilinear mapping
By definition the tensor product is the linear span of
The main feature is as follows. Any bilinear function (W is some other vector space) can be presented as follows
here is a linear mapping.
Likes GR191511
  • #32
Thanks
  • #33
In a general sense, the tensor product of two vector spaces over the same field is a third vector space , whose dimension is the product of those of and so that every bilinear map from , becomes a linear map from , for any vector space.
Idea is to transform multilinear maps into linear ones, as the latter are simpler and easier to deal with.
Likes wrobel and weirdoguy
