The third central moment of a sum of two independent random variables
Ad VanderVen
169
TL;DR Summary
Is it true that in probability theory the third central moment of a sum of two independent random variables is equal to the sum of the third central moments of the two separate variables?
Is it true that when X and Y are independent,
E ({X+Y}3) = E (X3)+E(Y3)?
This is just linearity of the expectation. You are assuming X and Y have expectation 0 and are independent. Develop (X+Y)^3, use linearity of E[.], then use independence and centrality to get E[X^2Y] = E[X^2]E[Y]=0 and E[XY^2] = E[X]E[Y^2]=0.
FAQ: The third central moment of a sum of two independent random variables
What is the third central moment?
The third central moment of a random variable is a measure of the asymmetry or skewness of its probability distribution. It is defined as the expected value of the cube of the deviation of the random variable from its mean, mathematically represented as E[(X - μ)^3], where X is the random variable and μ is its mean.
How do you calculate the third central moment of a sum of two independent random variables?
If X and Y are two independent random variables, the third central moment of their sum (Z = X + Y) can be calculated using the formula: E[(Z - μ_Z)^3] = E[(X - μ_X + Y - μ_Y)^3]. Given the independence of X and Y, this expands and simplifies to E[(X - μ_X)^3] + E[(Y - μ_Y)^3], which means the third central moment of the sum is the sum of the third central moments of the individual variables.
Why is the third central moment important?
The third central moment is important because it provides information about the skewness of a distribution. Skewness indicates whether the data is symmetrically distributed or if it tends to have a longer tail on one side. Positive skewness indicates a longer right tail, while negative skewness indicates a longer left tail.
What are the properties of the third central moment for independent random variables?
For independent random variables X and Y, the third central moment has the additive property: the third central moment of their sum is the sum of their individual third central moments. This property holds because the cross-product terms involving mixed moments vanish due to the independence of the variables.
Can the third central moment be zero?
Yes, the third central moment can be zero. When it is zero, it indicates that the distribution is symmetric around its mean. This symmetry means that the tails on either side of the mean are balanced, leading to no skewness in the distribution.
