Vernes
- 4
We have a discharge tube where the cathode is a cylinder with radius a and the anode is a coaxial cylinder with radius b, a<b. Both cylinders have length L, (Note that L can not be seen as large).The potential of the cathode is 0 and the potential of the anode is U>0. The electric field strength at the surface of the cathode is 0. If we assume that the electron cloud between the anode and cathode is uniformly distributed, what is then the total charge Q of the electron cloud?
[tex] \oint \bar E \cdot d\bar s = \frac {Q_{inside}} {\epsilon _0} [/tex]
[tex] \oint \bar E \cdot d\bar l = \Delta V [/tex]
My idea is to put a gaussian surface surounding the space between the anode and the cathode and then use Gauss's law to get the total charge inside. To be able to do this i need to know the electric field between the anode and the cathode and I can't seem to figure out how i can express this in a convenient way, mainly because L can't be seen as large and therefore I believe you need to consider the fringe effects? Maybe I should use the second equation to find the electric field but I can't seem to get my head around how this could be done.
