The total work in a Carnot cycle - checking some work
In summary, the conversation discusses finding the total work in a Carnot cycle with an isothermal expansion at temperature T, an infinitesimal adiabatic expansion at T-dT, and an isothermal and adiabatic compression back to the original state. The work expressions for each leg of the cycle are given and added together to find the total work. The question of whether this approach is correct is raised. Finally, the possibility of using the efficiency of the Carnot engine to determine the work produced as a function of dT and U is mentioned.
Emspak
243
Let the radiant energy in a cylinder be carried through a Carnot cycle. The cycle consists of an isothermal expansion at temperature T, an infinitesimal adiabatic expansion where the temperature drops to T-dT, ad returning to the original state via an isothermal compression and adiabatic compression. What is the total work in the cycle? Assume P= u / 3 where u is a function of T only.
To find the work in a Carnot cycle [itex] W= \int_{V_1}^{V_2} PdV[/itex], and a similar expression for points 2 to 3, 3 to 4 and 4 to 1.
The expansion from V1 to V2 would therefore look like this:
[itex]P = u/3 [/itex]
so for the first leg of the cycle [itex]W = \int \frac{u}{3} dV[/itex] and since the first leg is isothermal that would mean P is constant. So [itex]W=\frac{1}{3}u(T)(V_2-V_1)[/itex]
for the second leg of the cycle we can work from the total energy of the system. [itex]U = u(T)V[/itex]. And [itex]dU=u(T)dV + V\frac{du}{dT}dT[/itex]. Since the change of energy is equal to the work done, we can say [itex] W = u(T)dV + V\frac{du}{dT}dT[/itex] and if we add that to the first work expression and plug in the relevant values for V we have [itex] u(T)dV + (V_3-V_2)\frac{du}{dT}dT+ \frac{1}{3}u(T)(V_2-V_1)[/itex].
Since the cycle's third and fourth leg look the same as the first two (except with opposite signs and T-dT in the temperature) we can add up all four and we have:
[itex] -u(T)dV + (V_1-V_4)\frac{du}{dT}dT- \frac{1}{3}u(T)(V_4-V_3) + u(T)dV + (V_3-V_2)\frac{du}{dT}dT+ \frac{1}{3}u(T)(V_2-V_1).[/itex].
The dT terms cancel out
[itex] -u(T)dV + (V_1-V_4)du- \frac{1}{3}u(T)(V_4-V_3) + u(T)dV + (V_3-V_2)du+ \frac{1}{3}u(T)(V_2-V_1).[/itex].
and the u(T)dV terms seem to as well. But I wanted to check if I was going about this the right way. The answer we are supposed to get has a du in the nominator...
Can you use the efficiency of the Carnot engine operating between T and T-dT to determine the work produced as a function of dT and U?
AM
Related to The total work in a Carnot cycle - checking some work
1. What is a Carnot cycle?
A Carnot cycle is a theoretical thermodynamic cycle that involves a heat engine operating between two constant temperature reservoirs, one hot and one cold. It is an idealized cycle that serves as a benchmark for the maximum efficiency that can be achieved by any heat engine.
2. What is the total work in a Carnot cycle?
The total work in a Carnot cycle is the net work done by the system, which is equal to the difference between the work done by the system on the surroundings during the isothermal expansion and the work done on the system by the surroundings during the isothermal compression.
3. How is the total work in a Carnot cycle calculated?
The total work in a Carnot cycle can be calculated by using the formula W = Qh - Qc, where Qh is the heat absorbed from the hot reservoir and Qc is the heat released to the cold reservoir.
4. What is the efficiency of a Carnot cycle?
The efficiency of a Carnot cycle is the ratio of the net work done by the system to the total heat absorbed from the hot reservoir, expressed as a percentage. It is given by the formula η = (1 - Tc/Th) x 100%, where Tc is the temperature of the cold reservoir and Th is the temperature of the hot reservoir.
5. Can the efficiency of a Carnot cycle be greater than 100%?
No, the efficiency of a Carnot cycle cannot be greater than 100% as it is an idealized cycle that represents the maximum efficiency that can be achieved by any heat engine. In reality, the efficiency of a Carnot cycle is limited by factors such as friction and heat loss, which make it impossible to achieve 100% efficiency.
