The Trouble with TESS: Examining its Limitations in Exoplanet Observations
  • I
  • Thread starter Jenab2
  • Tags
    exoplanets
In summary, TESS was designed to find habitable planets around red dwarf stars, with the intention of finding planets with 10-day orbits or less. However, this mission design may not be adequate for its intended purpose of finding transiting exoplanets in the habitable zone of brighter stars. There are also concerns about the potential impact of discovering extraterrestrial life on our society.
Jenab2
85
The time required for the observation of three successive transits of an exoplanet in front of its primary star is the minimum time necessary for the confirmation of the exoplanet. Three transits, not two, are needed to establish the periodicity of the transits. Given only two dips in brightness, you don't know whether both of them were caused by the same transiting object, or by two different transiting objects.
The distance of an Earth-like exoplanet from its star is proportional to the square root of the ratio of the star's bolometric luminosity to the sun's bolometric luminosity.
R/au = (L/L๏)⁰·⁵
The mass-luminosity relationship at the lower end of the main sequence is, roughly,
L/L๏ = (M/M๏)³·²
So...
R/au = (M/M๏)¹·⁶
The Newtonian form of Kepler's Third Law,
(P/yr)² = (R/au)³/(M/M๏)
Doing the algebra,
P/yr = {(R/au)³/(M/M๏)}⁰·⁵
P/yr = { (M/M๏)⁴·⁸/(M/M๏) }⁰·⁵
P/yr = {(M/M๏)³·⁸}⁰·⁵
P/yr = (M/M๏)¹·⁹
M/M๏ = (P/yr)⁰·⁵²⁶³²
If the interval of time devoted to observation of a patch of sky is 27 days, then the largest period for an exoplanet, for which we might observe three transits within that interval, is 9 days.
If P=9 days, then
P/yr = 0.02464
M/M๏ = 0.1424 ← for luminosity class V, this is a spectral type M6 star.
That's a maximum mass for a star having an Earthlike planet that can be confirmed by TESS.
TESS' mission design does not seem adequate to its intended purpose. For stars of spectral types G and K, TESS will be able to find only hot Jupiters and other planets that are too near the star to be habitable.
Dr. Thomas Barclay was recently quoted in a Deep Astronomy video (posted on YouTube) as saying that TESS was intended to find only planets with 10-day orbits or less, and that it was the intention all along to find habitable planets only around red dwarf stars. I don't think that the public was aware of that. Besides that, we were told repeatedly that TESS was going to look at the "brighter stars." These red dwarfs aren't among the brighter stars.
Later in the same video, we are told that TESS wasn't optimized for exoplanets in the habitable zone. Too right, that! For the brighter stars, TESS just plain won't discover any exoplanets except for the very hot ones. You might think that the discoveries of lots of hot Jupiters can be handed over to the users of the JWST, so that it can find transiting exoplanets that are in bigger-than-9-day orbits, but this is a dubious assumption. Remember that the odds for transit diminish with increasing orbital distance for exoplanets. Just because you can see that very close, very hot exoplanet does not mean that you can also see a more temperate exoplanet orbiting in the same exo-ecliptic plane further out.
Probability of transit = (2/π) arcsin(R/a)
Where (R) is the star's radius and (a) is the planet's orbital radius. Although the relationship isn't quite linear, it is almost so, and, roughly speaking, when you double the exoplanet's orbital radius, you halve the odds for transit.
For exoplanets in 9-day orbits: Star Mass, Star spec, orbit distance (AU), Equilibrium bb Temp (K)
0.100 , M7 , 0.03930 , 237.7
0.200 , M4 , 0.04952 , 335.5
0.300 , M3 , 0.05669 , 344.8
0.400 , M3 , 0.06239 , 374.7
0.500 , M2 , 0.06721 , 452.8
0.600 , K9 , 0.07142 , 534.2
0.700 , K5 , 0.07519 , 633.2
0.800 , K2 , 0.07861 , 740.6
0.900 , G9 , 0.08176 , 846.1
1.000 , G2 , 0.08468 , 956.4
1.100 , G0 , 0.08741 , 1050.9
1.200 , F7 , 0.08998 , 1142.0
What would be ideal is for there to be an improved TESS orbiting the sun at 19.2 AU, probably in the Sun-Uranus L4 and L5 points, where it could devote 2562 days to each of 12 rows of scanning sectors, with each row stretching from the North Celestial Pole to the South Celestial Pole. After 84 years, it would have found every transiting exoplanet orbiting within the habitable zones of every star (having a mass of 1.2 suns or less) for which the S/N ratio was acceptably high, in addition to those hotter exoplanets to which the current TESS is sadly limited. If we didn't want to wait 84 years, we could launch twelve of those improved TESS probes and do the job in seven years.
Likes Buzz Bloom
Astronomy news on Phys.org
I believe by "brightest stars" they were referring to apparent magnitude, not absolute magnitude. But yes, it's mostly a red dwarf mission, the idea is that red dwarfs are so common that we could get some interesting exoplanets if we cast a wide enough net. I can't speak to issues like what kinds of missions would be better at finding Earths around G stars, Kepler would have been great for that had it not run into problems.
Likes Buzz Bloom
I know that the search for extraterrestrial life is of great interest but, apart from "knowing it's there", once it's been located, it wouldn't (needn't) affect our lives in any way. The other data that TESS and other projects can yield is probably a lot more useful but the public need to be sold the life package.
One way it could affect us could be the start of a maniacal extreme religious revival. We could really do without that!
FAQ: The Trouble with TESS: Examining its Limitations in Exoplanet Observations
What is TESS and why is it important in exoplanet observations?
TESS (Transiting Exoplanet Survey Satellite) is a NASA space telescope that is designed to search for exoplanets using the transit method. This method involves detecting dips in a star's brightness as a planet passes in front of it. TESS is important in exoplanet observations because it has a wide field of view and can survey a large portion of the sky, making it more efficient at finding exoplanets compared to other telescopes.
What are the limitations of TESS in exoplanet observations?
Despite its capabilities, TESS has some limitations in exoplanet observations. For one, its primary mission is only two years long, so it can only observe a small fraction of the sky. Additionally, its sensitivity to small, rocky planets is limited, and it can only detect exoplanets that are in relatively close orbits around their host stars.
How does TESS compare to other exoplanet hunting telescopes?
In terms of efficiency and capabilities, TESS is superior to other exoplanet hunting telescopes such as the Kepler and Spitzer space telescopes. TESS has a wider field of view and can survey a larger portion of the sky, making it more efficient at finding exoplanets. However, it is not as sensitive to smaller, rocky planets compared to the Kepler telescope.
Can TESS detect habitable exoplanets?
TESS is designed to detect exoplanets that are in relatively close orbits around their host stars. This means that it is more likely to detect hot, gas giant planets rather than smaller, rocky planets that may be in the habitable zone of their star. However, TESS can still contribute to the search for habitable exoplanets by identifying potential candidates for follow-up observations by other telescopes.
How can TESS's limitations be overcome in future exoplanet observations?
To overcome TESS's limitations, future exoplanet missions are being planned that will have more advanced technology and capabilities. For example, the James Webb Space Telescope (JWST) will have a larger mirror and improved sensitivity, allowing it to detect smaller, rocky exoplanets more easily. Additionally, ground-based telescopes, such as the upcoming Extremely Large Telescope, will also contribute to exoplanet observations by providing more detailed data on exoplanet atmospheres and compositions.
