The Uniquess of the Law of Cosines
  • B
  • Thread starter e2m2a
  • Tags
    Law
In summary, the law of cosines is the only valid expression that exists to determine the value of ##c## in a triangle, given the sides ##a, b## and the opposite angle ##\theta##. Any other expression would have to be equivalent to the law of cosines for all values of the variables. There are other formulas, such as the law of sines, tangents, cotangents, and Mollweide's formula, that give the same information, but the law of cosines is the only one that is consistently used in trigonometry. There may be alternative expressions, but they have not been widely adopted in textbooks. One example is the alternate form of the law of cosines, which has
e2m2a
359
Is the law of cosines the only equation that expresses the relations between the sides and angles of a triangle? (Other than the law of sines). For example: Suppose we have a triangle and sides a,b and the angle opposite of c is known. Then invoking the law of cosines, we know that c sq = a sq + b sq - 2abcos(angle). Is this the only valid expression that exists that tells us the value of c sq? Is it possible that other expressions, for example, (just making this up) that c sq = b * pi - cos(4 * pi) + a sq also gives us the same number determined by the law of cosines? Or, is the law of cosines the only valid expression giving us the correct answer. Has it been proven rigorously in mathematics or can it be proven that this the only unique expression that exists that gives us the right answer? And if this is the case, if an alternative expression is found that gives us the same value of c sq for some given values of a,b and angle, can this only occur if the alternative expression can be algebraically derived from the law of cosines?
Mathematics news on Phys.org
If you know ##a, b## and ##\theta## then there is a unique value for ##c##. You can look at ##c## as a function of three independent variables:
##c = f(a, b, \theta) = a^2 + b^2 - 2ab \cos \theta##
Any other expression that gave you ##c## would have to be numerically equivalent to this one for every value of the variables ##a, b, \theta##. In other words, ##c## as a function of these three variables is unique.
You could, of course, find an alternative way to write this expression, but it would simply be an identity based on a variation of ##\cos \theta##.
we have the
Law of cosines
Law of sines
Law of tangents
Law of cotangents
Mollweide's formula
sum of angles is pi
these all give the same information and we could find an infinite number of others though none have made it into the trigonometry books with regularity
I am a fan of the alternate form of the law of cosines
a=b cos C+c cos B
b=a cos C+c cos A
c=a cos B+b cos A
it has the advantage of not having squares but the disadvantage of having five variables instead of four
interesting. never knew this. thanks
Related to The Uniquess of the Law of Cosines
What is the Law of Cosines?
The Law of Cosines is a mathematical law that relates the lengths of the sides and angles of a triangle. It is used to find missing side lengths or angles in a triangle when given enough information about the triangle.
What makes the Law of Cosines unique?
The Law of Cosines is unique because it can be used to solve any type of triangle, regardless of its shape or size. Other trigonometric laws, such as the Law of Sines, can only be used for specific types of triangles.
How is the Law of Cosines derived?
The Law of Cosines is derived from the Pythagorean Theorem, which states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides. By rearranging this equation and substituting in trigonometric ratios, the Law of Cosines can be derived.
What is the formula for the Law of Cosines?
The formula for the Law of Cosines is c² = a² + b² - 2ab cos(C), where c is the length of the side opposite angle C, and a and b are the lengths of the other two sides.
What are some real-world applications of the Law of Cosines?
The Law of Cosines has many real-world applications, such as in navigation and surveying, where it is used to measure distances and angles. It is also used in physics and engineering to solve problems involving forces and vectors. Additionally, the Law of Cosines is used in computer graphics to create 3D models and animations.
  • General Math
  • General Math
  • General Math
