The universe and its matters: finite or infinite?
In summary: You can imagine 2D creature living on a curved surface of a planet, but you don't have to imagine a planet in 3D space to understand that. In summary, the universe has no edge, is expanding, and has no center according to current theories. The estimated number of galaxies is finite, while the number of particles and matters is unknown. There may or may not be a center of the universe, depending on the geometry of space. The balloon/sphere analogy helps to understand the concept of curved space, but it is not a requirement in the mathematical models. The observable universe is always finite due to the finite time since the Big Bang and the finite speed of light.
nemoover
It's been said that the universe has no edge, it's expanding, it has no center and the big bang was the birth of energy, matters and space-time.
I also often hear that it's been estimated the universe has approximately 200 billion galaxies or more or much more. Also the number of particles and matters is finite, otherwise we would have infinite amount of event, earth, you, me, star (the sky wouldn't be dark at night?) and scotch whisky (hell yeah!).
My question is where is the center of that collection of that 200 billion galaxies or any finite amount of particles? I mean if we had only 4 galaxies (or 4 stars) in the whole universe, we could calculate its center or its center of mass with any form of matter distribution and allocation in 3d space, right?
Many thanks!
Space news on Phys.org
I think the observer is always at the centre no matter if he is on Earth or moon . He is the centre of the universe.
Correct me if i am incorrect :)
nemoover, don't mix universe and observable universe
When you hear: universe has approximately 200 billion galaxies you should read: observable part of the universe has approximately 200 billion galaxies while the total number can be infinite if universe is infinite
Unfortunately, the word observable is being omitted in many cases.
Many thanks!
If you assume Euclidean geometry, then any set of points must have a "center". But in other geometries, that is not true. For example, four points on the surface of a sphere, in three dimensions, may have "center" at the center of the sphere. But thinking of the surface itself as the entire space, they have no center.
Good point, thanks, Dmitry67!
If the amount of particles/matters is an infinite number, then space, the universe and the number of light sources are infinite, certainly there's no center, would the sky be dark at night in this case?
But if the amount of particles/matters is a finite number, I cannot understand why there shouldn't be a center of the whole structure. For example, a Rubik's cube is made of many particles and they occupy a region of 3d space, we can calculate the center of the cube. The same math we can do with earth, solar systems, galaxies and a toilet paper roll (cylinder shape). Suppose the whole universe (not just the observable universe) has x amount of particles, no matter how they distribute in 3d space, should there be a center?
About the balloon/sphere analogy: Let's say there's a 2d creature live on the surface of that sphere, i understand there's no center on the surface and the the center of the sphere is not reachable (in another dimension...). But please consider this: If that creature choose a direction and keep going straight, eventually it will return to the original point/location. Let's name this point A, this creature also measured the distance it has traveled, call this distance D. So at D/2 there's a point B, now the imaginary straight line AB (just like Earth's north and south pole form a straight line) is the diameter of the sphere and center point C of AB is the center of the sphere. C coordinate (though not comprehensible) is calculable. If that analogy also works similarly with our 3d universe, given the Milky Way is pole A, where is pole B?
One last favor I may ask, could anyone help me with the math that led from WMAP measurements to this: http://en.wikipedia.org/wiki/Shape_of_the_Universe
Your responses are highly appreciated!
nemoover said:
1 If the amount of particles/matters is an infinite number, then space, the universe and the number of light sources are infinite, certainly there's no center, would the sky be dark at night in this case?
2 About the balloon/sphere analogy: Let's say there's a 2d creature live on the surface of that sphere, i understand there's no center on the surface and the the center of the sphere is not reachable (in another dimension...)
1 Because there is finite time from the Big Bang, light has finite speed, so we can see finite number of objects. The area we can potentially see is called an observable Universe, and as I explained above, it is always finite.
2 Becase it in only an analogy. Curved 2D space can be embedded in a higher dimension flat space (for 2D it is 3D) but it doesn't mean that such higher dimensional space is real. It helps you imagine the curved space, but it is not required mathematically.
Related to The universe and its matters: finite or infinite?
1. Is the universe finite or infinite?
The answer to this question is still unknown and remains a topic of debate among scientists. Some theories suggest that the universe is infinite, while others propose that it is finite but unbounded. More research and evidence are needed to determine the true nature of the universe.
2. How do scientists measure the size of the universe?
Scientists use various methods, such as observing the cosmic microwave background radiation and measuring the redshift of distant galaxies, to estimate the size of the observable universe. However, due to the limitations of technology and our understanding of the universe, the exact size is still uncertain.
3. What is the Big Bang theory?
The Big Bang theory is the prevailing cosmological model that explains the origin and evolution of the universe. According to this theory, the universe began as a singularity and has been expanding and cooling down ever since.
4. Are there parallel universes?
There is currently no scientific evidence to support the existence of parallel universes. However, some theories, such as the multiverse theory, propose the existence of multiple universes with different physical laws and properties.
5. Will the universe continue to expand forever?
Based on current observations, it is likely that the universe will continue to expand forever. However, this is not a definitive answer as the expansion rate may change in the future, and new discoveries may alter our understanding of the universe's fate.
  • Cosmology
  • Cosmology
