The value of the spring constant k that I calculate seems too high
In summary, the calculated value of the spring constant k appears to be excessively high, suggesting a potential error in measurement or calculation methods that may need to be reviewed for accuracy.
dannolul
A ball of mass 73kg starts at the top of a 52m high hill with a speed of 20.0 m/s. It rolls down the hill onto a spring and compresses it to a maximum of 46.5cm. Find the spring constant of the spring.
Et1=Et2
ek1+eg1+ee1=ek2+eg2+ee2
ek1+eg1=Ee2
Ek= kinetic energy (1/2mv^2)
eg=Grabitational energy (mgh)
Ee=elastic energy (1/2kx^2)
I expanded ET1=ET2 to get
(Total energy at top) 1/2mv^2+mgh = 1/2kx^2 (Total energy at bottom)
Rearanged i got
k = (mv^2+2mgh)/x^2
so [(73)(20)^2+2(73)(9.8)(52)]/0.465^2
=479137.945N/m
Please show the details of your calculation. Without them, we cannot find where and if you went wrong. Also, when you quote numbers you must attach units to them. 479000 is meaningless all by itself.
Oh Sorry, was on my phone and rushing.
Rearanged i got
k = (mv^2+2mgh)/x^2
=479137.945N/m
Rearanged i got
k = (mv^2+2mgh)/x^2
=479137.945N*m
You mean 479000 N/m. That’s what I got. Why do you think it’s too high? You have a 73 kg mass starting at the top of a 50 m hill initially at 45 miles per hour. When it starts compressing the spring, it’s moving at about 84 miles per hour. It must be quite a spring to stop that mass over a distance of about 2 feet.
Likes erobz, MatinSAR and dannolul
In class we havnt really talked about high k constant and only worked with small k constants. So it seemed a little skeptical as I didnt think it should be that high. Appreciate the help.
Other than the unusual input numbers, I am bothered by the solution that conserves energy without considering the rotation of the ball that is clearly said to "roll down the hill." Have you studied rotational motion? If so, you can recalculate the speed of the center of mass of the wheel taking the rotation of the wheel into consideration.
However, in that case one has to consider how the kinetic energy of the wheel is converted to elastic potential energy in the spring without energy dissipation by friction as the ball rolls (?) an additional 46.5 cm before it comes to rest.
Likes nasu
I suspect it was just unintentional wording. No radius for the ball either.
EDIT: never mind that is independent of the radius, I still suspect poor wording.
What would stop it rotation at the bottom; the friction with the ground? if so, all of its rotational kinetic energy would be lost to heat regardless, no? Or if there was no friction at the bottom (on either the ground or the spring) it would just be spinning freely at whatever angular velocity it had as it compressed the spring.
Exactly. One has to assume that there is no friction at the bottom. In that case only the translational kinetic energy will be converted to elastic energy which is results in the solution already obtained.
Likes erobz
What bothers me more is that mechanical energy would not be anywhere near conserved if you actually did what's described in this scenario.
You want to be careful with statements like this and the misconceptions they generate. Heat is a transfer of energy due to a temperature difference. The correct statement is that the rotational kinetic energy (or indeed any form of mechanical energy) is converted to internal energy.
This distinction becomes important when you study the First Law of Thermodynamics.
Likes erobz
It's not a good problem. I give it a C-.
The normal force from the spring will (soon) be much greater than that from the ground. Even a small frictional coefficient against the spring will lift it off the ground completely.
FAQ: The value of the spring constant k that I calculate seems too high
1. What factors could lead to an unusually high value of the spring constant k?
Several factors can contribute to an unusually high value of the spring constant k. These include measurement errors in the force or displacement used in the calculations, the material properties of the spring being tested, or even the method of attachment to the measuring apparatus. Additionally, if the spring is not in its linear elastic region, the calculated k may not reflect its true behavior.
2. How can I ensure accurate measurements of force and displacement?
To ensure accurate measurements, use calibrated equipment and take multiple readings to minimize random errors. Make sure the spring is at rest before taking measurements and that the force is applied uniformly. Using precise measuring tools, such as a digital force gauge and a ruler or caliper, can also improve accuracy.
3. Could the spring be damaged or fatigued, affecting the value of k?
Yes, if the spring has been subjected to excessive loads or repeated cycles beyond its elastic limit, it may have undergone permanent deformation or fatigue. This would affect its stiffness and lead to an inaccurate calculation of the spring constant k. Inspecting the spring for signs of wear or damage is essential before conducting experiments.
4. What is the significance of the spring's material properties in determining k?
The material properties, such as Young's modulus, yield strength, and the geometry of the spring, significantly influence the spring constant k. Different materials respond differently to stress and strain, which can affect how much force is required to achieve a certain displacement. Understanding the material's characteristics can help explain an unexpectedly high value of k.
5. How can I verify the calculated value of k?
You can verify the calculated value of k by comparing it with theoretical values derived from the spring's specifications or by conducting additional experiments using different methods, such as oscillation experiments. If possible, use a different spring of known k to cross-check your measurements. Consistency across various methods can help confirm the validity of your results.
