VertexOperator
- 79
Can someone please explain to me how water drops generate electricity? I saw this in a Walter Lewin lecture and became very curious to know :)
VertexOperator said:Can someone please explain to me how water drops generate electricity? I saw this in a Walter Lewin lecture and became very curious to know :)
The mechanism by which charge separation happens is still the subject of research.
VertexOperator said:Thank you :)
Yeah, looks very similar to lightning, but I still don't get how water drops get charged lol Is it because of friction with air or something?
A Review of Thunderstorm Electrification Processes
Field and laboratory evidence points to the importance of interactions between particles of the ice phase, in the presence of liquid water droplets, in separating electric charge in thunderstorms.
Bobbywhy said:I have built several Kelvin Water Droppers that generate high voltage by induction.
The best technical explanation of the theory of operation I’ve been able to find is by Bill Beaty here:
http://amasci.com/emotor/kelvin.html
Cheers, Bobbywhy
THE BASIC THEORY
Even though water has no overall electric charge, it is full of movable electric charges (called ions). Half of the water's charges are positive and half are negative.
I originally didn't understand simple electrical physics at all, but I didn't know it (this after getting a BS in Electrical Engineering!) Later I finally figured out what was wrong, fixed my problems, and now I understand it pretty well.
OmCheeto said:I know water molecules are polarized, but that statement says they are ions.
nsaspook said:Tap water normally has dissolved salts and other chemical impurities that make it electrically conductive by ion flow.
Bobbywhy said:... that generate high voltage by induction.
Cheers, Bobbywhy
wiki said:Electromagnetic induction is the production of a potential difference (voltage) across a conductor when it is exposed to a varying magnetic field.
wiki again said:the two materials only need to come into contact and then separate for electrons to be exchanged. After coming into contact, a chemical bond is formed between some parts of the two surfaces, called adhesion, and charges move from one material to the other to equalize their electrochemical potential. This is what creates the net charge imbalance between the objects. When separated, some of the bonded atoms have a tendency to keep extra electrons, and some a tendency to give them away
willem2 said:Even pure water has a concentration of 10^(-7) OH- and H+
The drops are already charged by the time they start falling. Once the drops are falling, they don't accumulate any additional charge. As explained in Beatty's article, what the inducers do is cause the water in the upper cans to separate into ionized layers, repelling the ions with like charge away (upwards) from the inducers, and attracting the ions with opposite charge towards the inducers (downwards), so that the drops of water have the opposite charge of the inducers. As the charge increases, the water drops start to scatter due to attaction towards the inducers, until a spark occurs, resetting the system back to a near neutral state.Bobbywhy said:In the Kelvin Water dropper the two upper metal rings (or cylinders) are called “inducers” because they charge the falling water drops by electrostatic induction.
OmCheeto said:Induction?
Bobbywhy said:...for instance. It’s important to not confuse electrostatic induction with electromagnetic induction.
If there is a better description of the detailed theory of operation of the Kelvin Water Dropper than Beatty’s then it would be great to read it.
Cheers, Bobbywhy
An interesting point in Prof Lewin's video is that his set-up departs from the usual description of how this needs to be arranged. His set-up seems to differ from his own diagram, too.OmCheeto said:Ah ha! I found Lewin's video.
Bobbywhy said:Here is a tutorial and an excellent description of the detailed theory of operation of the Kelvin Water Dropper at the website of the National High Magnetic Field Laboratory. It provides a clearly written and definitive explanation of how the electrostatic generator works. See:
http://www.magnet.fsu.edu/education/tutorials/java/kelvinwaterdropper/index.html
Cheers, Bobbywhy
The process of generating electricity from water drops is known as the triboelectric effect. This occurs when two materials come into contact and then separate, causing a transfer of electrons between the two surfaces. In the case of water drops, the surface tension of the water causes it to spread out upon contact with a surface, creating a larger surface area and allowing for a greater transfer of electrons.
The triboelectric effect occurs in water drops due to the difference in surface properties between the water and the surface it comes into contact with. The surface tension of the water allows it to spread out and form a larger contact area, increasing the likelihood of electron transfer between the two surfaces.
Materials with a high surface energy, such as Teflon or silicone, are commonly used to generate electricity from water drops. These materials have a strong attraction to water and can create a large contact area, allowing for a greater transfer of electrons.
The amount of electricity generated from water drops varies depending on the size and frequency of the drops, as well as the materials used. However, research has shown that even small drops can generate enough electricity to power small electronic devices.
Some potential applications of using water drops to generate electricity include powering small electronic devices, such as sensors or wearables, and providing a sustainable source of energy for remote or disaster-stricken areas. It can also be used in water harvesting systems to generate electricity while collecting and purifying water for human use.
