The wave function is an exponential function, if I plot the
In summary, the wave function is not represented by a trigonometric ratio because it is a solution to Schrodinger's equation for a specific system and can take the form of exponentials, sinusoids, or Hermite polynomials. It cannot be plotted on the real axis alone, but any measurement made using the wave function must be real. The imaginary part of the wave function is necessary for mathematical convenience and stems from using complex exponentials. The WKB approximation shows that positive energy results in sinusoidal wave patterns, while negative energy results in exponential patterns. Real wave functions cannot be pure sinusoids as they must decay spatially to represent a localized particle.
LSMOG
62
The wave function is an exponential function, if I plot the real part of it, I don't get a wave graph like sine or cosine function, Why the wave function is not represented by a trigonometric ratio instead.
Also, the wave function cannot be plotted since it is imaginary, why is it imaginary?
Thanks
The wave function need not be a pure sinusoid, but instead a solution to Schrodinger equation for the system in question which may be exponentials e.g. a free particle with energy higher than a constant potential or sinusoids (a free particle with energy lower than a constant potential) or a Hermite polynomial multiplied by Gaussian exponentials (a harmonic potential)... You might be able to convince yourself from Euler's equation that exponentials are very closely related to waves and even provide valid solutions to the standard wave equation.
The wave function cannot be plotted, in general, on the real axis alone. But any measurement you make using the wave function must be real and can be plotted on the real axis. The wave function is imaginary for mathematical convenience/necessity. It stems from using complex exponentials to compactly describe both the amplitude and phase of a wave.
In the WKB approximation, you get sinusoidal wave patterns where the energy is positive, and exponential patterns where the energy is negative.
No real wave function can be a pure sinusoid. The function f(x)=sin(x) or f(x)=cos(x) is not normalizable. It makes sense that real wave functions decay spatially since a particle is at least partially localized to some region of space. A particle should not be spread out throughout all of space.
Related to The wave function is an exponential function, if I plot the
1. What is the wave function?
The wave function is a mathematical expression that describes the quantum state of a system. It is used to calculate the probability of finding a particle in a certain position or state.
2. What does it mean for the wave function to be an exponential function?
An exponential function is a mathematical function with a constant base raised to a variable power. In the case of the wave function, the constant base is the imaginary number i, and the variable power is the position of the particle. This allows the wave function to model the oscillating behavior of quantum particles.
3. How is the wave function plotted?
The wave function is typically plotted on a Cartesian coordinate system, with the horizontal axis representing the position of the particle and the vertical axis representing the amplitude of the wave function.
4. Why is the wave function important in quantum mechanics?
The wave function is a fundamental concept in quantum mechanics, as it allows us to understand and predict the behavior of quantum particles. It is used in many calculations and equations, including the Schrödinger equation, which is the foundation of quantum mechanics.
5. Are there any limitations to the wave function as an exponential function?
While the wave function is a powerful tool in quantum mechanics, it does have limitations. For example, it cannot fully describe particles with spin, and it also cannot accurately predict the exact position and momentum of a particle at the same time due to the uncertainty principle.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
