The way helicopters are able to operate
  • Thread starter Ry122
In summary, if a helicopter increases its omega of blades while in the air without doing so while fixed to the ground first, it will cause the body and rotor to rotate in opposite directions due to Newton's 3rd law of torque. This can be countered by using a tail rotor, which results in the helicopter needing to lean in the direction of the tail rotor's thrust for a stable hover.
Ry122
565
If a helicopter was to increase its omega of blades while in the air, and not completely do it while fixed to the ground before taking off, why would this cause the body and rotor to rotate in opposite directions while the helicopter is airbourne? This is assuming no air resistance. And no bearing friction. omega = radial velocity
It's Newton's 3rd law applied to torque. The helicopter exerts a torque on the main rotor, and the main rotor exerts and equal and opposing torque onto the helicopter. Usually a tail rotor is used to counter the torque exerted by the main rotor onto the helicopter, which results in a net side force, so for a true hover, the helicopter has to lean a bit into the direction of thrust from the tail rotor.
Related to The way helicopters are able to operate
1. How do helicopters stay in the air?
Helicopters are able to stay in the air due to the lift generated by their rotating blades. These blades are shaped in a way that creates a difference in air pressure, with the air moving faster over the curved surface of the blades and creating a lower pressure area on top. This allows the helicopter to stay airborne.
2. What is the purpose of the tail rotor on a helicopter?
The tail rotor on a helicopter serves a crucial role in ensuring stability and control during flight. It counters the torque produced by the main rotor and prevents the helicopter from spinning uncontrollably.
3. How are helicopters able to fly in different directions and hover in place?
Helicopters have a swashplate mechanism that allows the pilot to control the pitch of each rotor blade individually. By changing the pitch of the blades, the pilot can control the lift and direction of the helicopter, allowing it to fly in different directions and hover in place.
4. What is the maximum altitude that a helicopter can reach?
The maximum altitude that a helicopter can reach depends on various factors, such as the type of helicopter, its weight, and the weather conditions. Generally, helicopters can fly up to 25,000 feet, but some specialized models can reach altitudes of 40,000 feet or more.
5. How does a helicopter's engine work?
Most helicopters use a gas turbine engine, which consists of a compressor, combustion chamber, and turbine. The compressor sucks in air and compresses it, which is then mixed with fuel and ignited in the combustion chamber. The hot gases produced by the combustion process then pass through the turbine, which powers the engine and turns the main rotor blades.
26K
  • Mechanical Engineering
9K
