The weak force and effective coupling
In summary, the creation of deuteron in the first step of the pp cycle involves a weak interaction due to the presence of a neutrino. While weak interactions usually occur at low energies, the 1.5 x 10^7 K temperature in the Sun's core is not considered high energy. This is because the energy is only around 1.3 keV per proton, which is relatively low compared to the masses of the particles involved. As a result, the process does not involve the production of intermediate gauge bosons and instead relies on other factors such as the nucleons involved not fragmenting.
ian2012
80
I just read something about the creation of deuteron in the first step of the pp cycle. Given that you have the reaction: p + p -> d + e^+ + v_e, where e^+ is a positron and v_e is an electron neutrino. Since there is a neutrino present, it is a weak interaction. In addition, as the interaction is weak (and at low energies?) the effective coupling is small.
My question is, do weak interactions only proceed at low energies? I have read about 'low energy limits' and how this means only virtual W's can be made. How is it then that this process can proceed at roughly 1.5 x 10^7 K in the Sun's core?
Weak interactions in generally occur most readily at energies where the intermediate gauge boson is very close to its mass shell (about 80 GeV for the W and 90 GeV for the Z). However, at that kind of energy the nucleons involved tend to fragment, so you wouldn't get deuterium.
Also, not that 1.5 x 10^7 K does not get you to terribly high energy. It only amounts to an avererage of 1.3 keV kinetic energy per proton, which is, as these things go, rather low energy. (Remember, the electron's mass is 511 keV and the proton's is 938 MeV.)
Okay then, so weak interactions don't really proceed at low energies? (i am not too sure what the ideal energies are for strong interactions).
Related to The weak force and effective coupling
1. What is the weak force?
The weak force is one of the four fundamental forces of nature, along with gravity, electromagnetism, and the strong force. It is responsible for radioactive decay and plays a crucial role in the stability of atoms.
2. How does the weak force work?
The weak force is carried by particles called W and Z bosons. It is a short-range force, which means it only acts over very small distances. The strength of the weak force is determined by the effective coupling constant.
3. What is the effective coupling constant?
The effective coupling constant is a measure of the strength of the weak force. It takes into account the effects of virtual particles and is dependent on the energy scale at which the interaction occurs. At low energies, the weak force is relatively weak, but at high energies, it becomes stronger.
4. How does the weak force affect everyday life?
The weak force is responsible for nuclear reactions that power the sun and other stars. It also plays a crucial role in the production of elements in the universe. Without the weak force, there would be no life on Earth as we know it.
5. Can the strength of the weak force be changed?
The strength of the weak force is a fundamental constant of nature and cannot be changed. However, scientists are constantly working to better understand the weak force and its interactions with other fundamental forces, which may lead to new discoveries and advancements in our understanding of the universe.
10K
