MHB The work energy principle and power
The discussion centers on calculating the final speed of a 25kg box pulled 5m across a smooth floor with a tension of 22N at a 40-degree angle and an average frictional force of 12N. The net work done on the box is calculated using the formula W_net = [22cos(40) - 12] * 5, leading to the conclusion that the final speed should be 1.39 m/s. This result aligns with the textbook answer, contrasting with an initial calculation of 1.97 m/s. The correct application of the work-energy principle is emphasized in determining the final speed. The accurate final speed is confirmed to be 1.39 m/s.
Shah 72
MHB
A box of mass 25kg is pulled 5m across a smooth floor by rope with tension 22N. The rope is inclined at 40 degree to above the horizontal. There is a frictional force with average value 12N. The box starts from rest. Find the final speed.
Iam getting the ans 1.97m/s.
The textbook ans is 1.39 m/s
Pls help
Mathematics news on Phys.org
$W_{net} = [22\cos(40) - 12]\cdot 5 = \dfrac{1}{2} \cdot 25 \cdot v_f^2 \implies v_f = 1.39 \, m/s$
Thank you!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
