The work of magnetic force on the wire
In summary, when two current carrying wires with identical current directions attract each other, it seems that the magnetic field does work while we know that the magnetic force is perpendicular to the velocity of charge. There is also a neutralizing force from the transverse electric field of accumulated charge across the wire, as observed in the Hall effect. The two forces oppose each other but do not usually balance. In the old cgs system of units, these forces were used to define the units of electric and magnetic field strength. Maxwell noticed that their ratio was equal to the speed of light, leading him to propose that light was electromagnetic. When a battery is used to increase the kinetic energy of the electrons in the wire, the battery works but the magnetic field does not
hokhani
483
When the two current carrying wires (with identical current directions) attract each other, it seems that the magnetic field of wires do work while we know that magnetic force is perpendicular to the velocity of charge. I would like to know whether the the two wires get closer or not? What about the neutralizing force of transverse electric field of accumulated charge across the wire (as occurs in Hall effect)?
It is interesting that the two forces oppose each other but do not usually balance.
In the old cgs system of units, the forces were used to define the units of electric and magnetic field strength. Maxwell noticed that their ratio was equal to the speed of light, and this led him to suppose that light was electromagnetic.
Could you please tell which two forces; The forces between the two wires (action and counteraction) or the transverse electric force and magnetic force on the moving charges?
Sorry I misunderstood your original question. The Hall effect is surely very small - we know from observation that wires attract.
It appears as the magnetic field does work here but this is NOT true. A more careful examination of the hall effects involved, reveals that the work is done by the electric field (electrostatic forces between the stream of electrons and the surface charge build up of hall effect). I had made a threat where I explain this in detail. Give me a sec to locate it
https://www.physicsforums.com/threads/hall-voltage-vs-laplace-force.879412/
Read especially post #6.
Likes hokhani and vanhees71
Two wire are coming closer with increasing kinetic energy that is supplied with battery, not from magnetic field generated by the current, I think.Battery works. Magneric field does not work.
Direction of current electrons is curved and deviated by magnetic field. Electrons are constrained within wire. As a simple model electrons collide with wire surface boundary and transmit momentum and energy to wire body. Battery provide energy to help electrons have their original speed relative to wire body. This is interpreted as increase of resistance of wire.
So we may say batteriy lasts longer when wire is alone than there is another current wire nearby.
Likes Delta2
I have my doubts about momentum because internal forces cannot change the overall momentum of a system ( the wire is a system of electrons+positive ions) but yes I believe the force between the electrons and the surface charges at the boundary of wire is what does the work, as internal forces can do work.
I believe the magnetic field force is responsible for the change in momentum of the wire, but internal forces between electrons and ions are responsible for the change in kinetic energy of the wire.
I think the electrons immediately become gathered by magnetic force on one side of the wire and the electric force of them on the moving electrons cancels the magnetic force and so the moving electrons can go in a straight line without deviation. However, the reaction electric force of these non-deviated electrons, on the electrons gathered on the side of the wire, causes motion of the wire. Therefore, it is the electric field that does work.
On the other hand, we expect the gathered electrons on the sides of the two wires repel each others (suppose the same direction of currents for the two wires) and so a repulsion force between the two wires. It seems a discrepancy here, because on one hand, we expect the two wires become closer but on the other hand they repel each other. The third possibility is that these two forces cancel each other and the wires remain fixed without moving.
Likes Delta2
I agree completely with the above
That repulsion force (assuming same direction of current for the two wires) is small compared to the Laplace force. However if the wires are placed very close then this repulsion force might not be negligible. But when the wires are placed too close, the Laplace force becomes bigger as well. Maybe it is safe to say that the repulsion force is negligible in comparison to the Laplace Force.
Both Laplace and repulsion forces become stronger as the wires get closer. It seems that these two forces cancel each other. We should see, by experiment, what really happens when the two current-carrying wires are placed close together. I haven't tried this experiment, so far.
Yea I feel uneasiness about Newton's third law concerning Lorentz force. Say Lorentz force push electron as action, as reaction electron push what ? EM field must be the answer but how it actually is?
Of course, the physical reason for introducing fields is relativity to have momentum conservation without action-at-a-distance interaction which are impossible in relativistic theories. In special relativity we have the same 10 space-time symmetries as in Newtonian physics and thus also the same 10 related conserved quantities (energy, momentum, angular momentum, center of momentum (not mass anymore as in Newtonian mechanics!)).
The Lorentz force can be derived from the action principle, leading to the balance equation for momentum. There you'll see that both matter and the electromagnetic field carry momentum, and the em. forces are given by Maxwell's stress tensor (which is part of the symmetric gauge invariant Belinfante energy-momentum tensor of the field).
Likes sweet springs
Thank you. I relearned the equation of motion of charged particle and em field as
[tex]\frac{d}{dt}[\ p^\alpha+\frac{1}{c^2}\int N^\alpha dv\ ]=\int T^{\alpha\beta}dS_\beta[/tex]
where alpha,beta =1,2,3 for space region of volume v and surface S, p is momentum of charged particle, N is Poynting vector and T is em stress tensor.
Likes vanhees71
Related to The work of magnetic force on the wire
1. What is magnetic force?
Magnetic force is a fundamental force of nature that is responsible for the attraction or repulsion between magnetic materials. It is caused by the interaction between moving electric charges and magnetic fields.
2. How does magnetic force affect a wire?
Magnetic force can exert a force on a wire that is carrying an electric current. This is because the moving charges in the wire create a magnetic field, which interacts with the external magnetic field to produce a force on the wire.
3. What factors affect the strength of magnetic force on a wire?
The strength of magnetic force on a wire depends on the strength of the external magnetic field, the current flowing through the wire, and the length of the wire that is exposed to the magnetic field.
4. How is the direction of magnetic force on a wire determined?
The direction of magnetic force on a wire is determined by the right-hand rule. If the thumb of your right hand points in the direction of the current flow in the wire, and your fingers curl in the direction of the external magnetic field, then the direction of the force on the wire is perpendicular to both your thumb and fingers.
5. What are some practical applications of the work of magnetic force on a wire?
Magnetic force on a wire is used in many applications, such as electric motors, generators, and transformers. It is also used in magnetic levitation technology, where the force between a magnet and a wire is used to suspend an object in mid-air.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Sticky
  • Electromagnetism
