Theoretical Or Engineering Project
In summary, as a student of Computer Science and Engineering, the conversation revolves around a student who is currently in their 4th year and 10th semester. They have been focusing on CS topics and planned to do a research on 'Degree Constraint Minimum Spanning Tree', but their assigned adviser proposed a hardware project that is an expansion of their published paper on 'Electronic Spring'. The student has been struggling with their DCMST research and is seeking advice on whether to stick with it or switch to the hardware project. They are ultimately looking to publish a good paper and secure a scholarship from a good university. It is advised for the student to consider the benefits, time, skills, and cost of each option before making a decision.
TheMadman
Hi!
I'm a student of Computer Science And Engineering. Currently at the 4th year, 10th semester. During the last years I've been giving emphasize on CS topics, not Engineering. I planned to do a research on 'Degree Constraint Minimum Spanning Tree'. But recently at my school my assigned adviser proposed me to do a project that is from hardware side. It is an expansion of his published paper on 'Electronic Spring'. I've to develop an interface to control the circuit and logic from a computer.
I've been working on DCMST from past few months, without any significant progress. Except that I re-discovered mmm... kruskal's algo. Not same, but the idea was same. My plan is to publish a good paper so that I can use it as reference of my research experience and get a scholarship from a good uni.
I think I'm weak on electronics. But, I'm confident that I can cope up with anything since I'm a quick learner.
It will be good to mention that my ultimate goal at this moment is to publish a very good paper.
Anybody can advise me what should i do?
Should I stick to my DCMST research or should I go for the hardware project?I would advise that you consider the benefits of each option before making your decision. For instance, if you want to publish a paper, will a research project in DCMST give you better chances than the hardware project? Also, consider the time it would take for you to complete either project. In addition, think about the skills you will learn through either project and how they might help you in the future. Finally, consider the cost of completing either project and if you can secure the necessary resources. Ultimately, you will need to decide which project will best benefit you and your career goals.
FAQ: Theoretical Or Engineering Project
What is the difference between a theoretical and engineering project?
A theoretical project focuses on developing new theories and concepts, while an engineering project focuses on applying existing theories to create practical solutions.
What are the key components of a theoretical or engineering project?
The key components of a theoretical or engineering project include a clear problem statement, research and data collection, hypothesis or design, data analysis and interpretation, and a conclusion or solution.
How do you determine the feasibility of a theoretical or engineering project?
The feasibility of a project is determined by considering factors such as available resources, time constraints, potential risks and challenges, and the likelihood of achieving the desired outcome.
What is the importance of testing and evaluating a theoretical or engineering project?
Testing and evaluating a project is crucial to ensure that the proposed solution or theory is valid, reliable, and effective. It also allows for potential improvements and adjustments to be made before implementation.
How do you communicate the results of a theoretical or engineering project?
The results of a project can be communicated through various means, such as technical reports, presentations, and publications in scientific journals. It is important to clearly and accurately present the data and findings to the intended audience for proper understanding and evaluation.
