- #36
Epsilon Pi
- 193
We certainly are using almost the same concepts, but the difference is, that I use to represent them, the complex basic unit system concept, that permits us to think in terms of closed loops or strings naturally, and even in terms of a radical duality, a necessary requisite when coping reality at those QM levels.Antonio Lao said:Read your paper. Thanks. Will read the other papers at xxx.lanl.gov site.
The topological geometric structure of H+ and H- is that of a closed loop of 1D string. But it will take two loops to form an H(+/-) structure. This structure can be said to be isomorphic to a doubly twisted Moebius strip or Hopf ring.
Another important advantage of this concept is that we can put under it all the fundamental equations of physics. i.e., under the same symbolic mathematical representation.
Here again we agree to a certain extent, being the difference again a sound symbolic complex mathematical representation as the BUS.Antonio Lao said:The intermediate level of reality you mentioned I would call it a fractal reality of fractal dimension (fractional dimension) between complete chaos and complete order. The midpoint reality is a theory of complexity (a complex adaptive system). These formed a trinity of physical states of energy (chaos), matter (complex adaptive system) and space (order).
The intermediate level of reality in fact has a mathematical representation in the complex plane, that I have found quite akin to the concept of form that biologists are using when dealing with life, as life can be defined as an animated form.
When dealing with open dynamic systems, before acquiring the steady state or its resonant state, we certainly have many frequencies, or a chaos of frequencies, but once that state is reached we have the inherent resonant frequency, or order. It is not quite correct to say that chaos is the origin of that order from this point of view.
And yes there you have the need of a triadic symbolism that can be expressed mathematically by complex numbers or the BUS concept.
And thank you so much for your time!
Regards
EP
